Main : Members : ca18det_man Autronic SMC
[<   Previous  17  18  19  20  21  22  23  Next   >]
Autronic SMC
Autronic SMCPopular
Submitterca18det_manMore Photos from ca18det_man   Last Update2005/2/14 11:42    Tell a friendTell a friend
Hits3292  Comments5    0.00 (0 votes)0.00 (0 votes)
A good ECU has lots of good opions but pretty complex to setup (compared to microtech ) Its controls boost ect. fully sequential ignition and fuel. Its setup to protect engine too limits boost and revs until warm and also lowers rev limit and boost when overheating
dattodude
Posted: 2005/2/14 22:20  Updated: 2005/2/14 22:20
 Re: Autronic SMC
Hey..the small filter is a good idea. Thanks
ca18det_man
Posted: 2005/2/15 8:45  Updated: 2005/2/15 8:45
 Re: Autronic SMC
No worries Chris it keeps any crap out of the ECU. When your close to getting yours going do you want a map??? Ours should be pretty much the same it shoudl at least get it running.
Cheers Andrew
dattodude
Posted: 2005/2/15 10:10  Updated: 2005/2/15 10:10
 Re: Autronic SMC
Yeah send it down. that'd be great. I don't know how I'd use it yet, as I've not had my laptop connected to my ECU yet. But all the same, it's gotta be a good start.
chris_at_shoeys.com
I'll obviously need to tweak the outputs to suit what I plan to do with them.
Did you find a source for new pins for the ECU connector? I'm thinking that I might need to use one more output than you. I want to run 2 fans via the ECU, and have them come on at different temps.
I was looking at the wreckers and I think that the later model Hondas use similar pins in their connectors.
Cheers,
Chris
ca18det_man
Posted: 2005/2/15 11:29  Updated: 2005/2/15 11:29
 Re: Autronic SMC
You will need an old type Laptop with a serial port to connect I have I think two spare pins for my ecu cant remember exactly what it was to be used for. Did you want the fans controled at different temps??? if not you could always just use the one output into a relay and work both thermoes off that?? Im yet to hook a computer upto mine Im looking at a cheap old Laptop hopefully will be good for datta logging ect
sunny
Posted: 2005/2/14 14:15  Updated: 2005/2/14 14:15
 Re: Autronic SMC
a great computer, I helped a friend tune one in his land cruiser 60 series wagon, blown v8
very complex set up , with the ability of injector timing and heaps of others. good choice
geoff
