Main : Misc Piston rings - which way up?
[<   Previous  5604  5605  5606  5607  5608  5609  5610  Next   >]
Piston rings - which way up?Popular
Submitterdatrat_daveMore Photos from datrat_dave   Last Update2005/2/21 9:35    Tell a friendTell a friend
Hits2589  Comments8    0.00 (0 votes)0.00 (0 votes)
I did this in paint, yes its dodgy i know....
datrat_dave
Posted: 2005/2/21 9:38  Updated: 2005/2/21 9:38
 Re: Piston rings - which way up?
Right so in the manual it clearly states that the 2nd groove ring (compression ring) must
have the beveled edge pointing upwards but in the handout in the rings box it said it should be downwards....Im confused and need this info before going ANY further!!
Advice plz!
Cheers
Dave
dattodevil
Posted: 2005/2/21 9:44  Updated: 2005/2/21 9:44
the bevelled edge is there to dodge the ridge in the bore, as alot of people don't go to the expence of a rebore
datrat_dave
Posted: 2005/2/21 10:02  Updated: 2005/2/21 10:02
so therefore the bevelled edge must face upwards other wise it could catch on the side right?!
Dave
dattodevil
Posted: 2005/2/21 10:13  Updated: 2005/2/21 10:13
So I believe, I am no engineer though and it has been a while since my last rebuild, But from memory the bevelled ring was on the top, Repco brought them out as ridge dodgers (protec rings).
Dodgeman
Posted: 2005/2/21 10:18  Updated: 2005/2/21 10:18
Follow the instructions on the packaging that the rings came in. If you bought factory Datsun rings that were identical to the originals,... then the book info would apply.
If they are "replacement" rings, stick with the ring manufacturers instructions.
kegs
Posted: 2005/2/21 10:55  Updated: 2005/2/21 10:55
exactly what dodgeman said, its on the instructions ive build many motors and never seen a packet that didnt tell u how to do it.
feral
Posted: 2005/2/21 12:25  Updated: 2005/2/21 12:25
If they are ACL or similar they will have a dot or mark on the top of the ring near the ring gap.
Check the ring gaps before fitting to the pistons..
Cable_Tie
Posted: 2005/2/22 1:28  Updated: 2005/2/22 1:28
Have a look here
Ring install
As I was told many years ago: (sexual content?)
In regard to the bevel/chamfer on the ring:
If it is on the inside, it is UP
If it is on the outside, it is DOWN
Just like bedroom activity. Hey, it has helped me remember it all these years on!
