Main : Members : bent_axel_bob adaptor
[<   Previous  14  15  16  17  18  19  20  Next   >]
adaptor
adaptorPopular
Submitterbent_axel_bobMore Photos from bent_axel_bob   Last Update2002/11/16 12:56    Tell a friendTell a friend
Hits5359  Comments4    0.00 (0 votes)0.00 (0 votes)
adaptor plate welded to manafold for webber carb took this before i cut out the middle and then diddent get a pic before i put it on doh
Posted: 2002/11/16 21:24  Updated: 2002/11/16 21:24
 Re: adaptor
If you find the low-throttle performance suffers, put the stock A12 intake tube back in (primary side only!) ... with my Weber it increased part-throttle response very nicely.
jaimecidpedro
Posted: 2003/1/26 10:34  Updated: 2003/1/26 10:34
 Re: adaptor
This is strange, my manifold has no separatio, it is one big opening, but smaller than the adaptor.So I can put the adaptor on top of the manifold and grind to equate sizes, no problem about thining down the wall of the manifold too much?
Posted: 2003/1/26 18:59  Updated: 2003/1/26 18:59
 Re: adaptor
The opening in the stock manifold is fairly large. On my A12, I didn't enlarge it. You can see how big the stock opening is in this pic:
jaimecidpedro
Posted: 2003/1/27 8:17  Updated: 2003/1/27 8:17
 Re: adaptor
The adaptor that came w/ my 32/36 looks like the adaptor on the left,no separations, just a larger opening on one side, like that one, but when sitting it on the manifold,the manifold(trying to remember, I have not seen it since replacing the carbie ) ... was smaller, so part of the intake flow must hit this area.I think my manifold is smaller on one side, larger on the other, but the semicircles never touch each other, no connection, , I will double check.
Jaime
