Main : Misc : Forum 120 y diff
[<   Previous  492  493  494  495  496  497  498  Next   >]
120 y diff
120 y diffPopular
Submitter120flyMore Photos from 120fly   Last Update2005/3/22 11:05    Tell a friendTell a friend
Hits2736  Comments4    0.00 (0 votes)0.00 (0 votes)
the diff out of a 120y
Dodgeman
Posted: 2005/3/22 12:58  Updated: 2005/3/22 12:58
 Re: 120 y diff
If this rear axle assembly is from a B210 /120Y, then the diferential will be an H150.
L18_B110
Posted: 2005/3/23 0:33  Updated: 2005/3/23 0:33
 Re: 120 y diff
that's the jap diff. The BorgWarner you want is a 'rear-loader'. It has a removeable plate on the back to fit the diff centre, whereas the jap diff as pictured has the diff centre mounted in a carrier that bolts into the diff housing from the front. That's probably the best I can explain it in simple terms.
oh, and if you're looking through the wreckers at 120Y's you'll pick the difference as soon as you see the 2 different diffs they have - the BorgWarner is huge compared to the jap H150.
The Jap H150 is found in the fully imported 120Y models coupes, and the sedans all seem to be assembled and have the BorgWarner diff.
tom210
Posted: 2005/3/24 23:48  Updated: 2005/3/24 23:48
 Re: 120 y diff
what is better eg. strength, ratios, weight?
Freak
Posted: 2005/3/22 12:44  Updated: 2005/3/22 12:44
 Re: 120 y diff
Could somebody please clarify for me if this is a h150 or borgwarner. The photo doesn't allow me to notice the actual size difference so can someone in the know enlighten me?
