[< Previous 1123 1124 1125 1126 1127 1128 1129 Next >]
GENERAL LEE
General 2005/4/25 6:49 Tell a friend
3616 14 0.00 (0 votes)
A-15 .080 over 11:1 compression 279 duration cam (232@.050) and .460" lift The cam is installed straight up and is ground on a 106 intake centerline with a 108 lobe center ported/polished A-15 head oversize valves (40mm intake and 32mm ex) Nismo Header MSN 6A Ignition Box Elec. Ignition Redline Intake with a couple 40 mm DCOEs 30 venturi 45F9 IDLE JET 130F11 MAINS 50 ACC JET JE full floting forged pistons in the engine and I can provide those specs to you if I can dig up the spec sheet that came with them. The engine has ARP head and main studs along with ARP rod bolts. The engine was balanced. Installed a tilton 10 lb aluminum flywheel with a centerforce clutch Future plans are to install a H190 rear end with disks and 4.10 gears and possibly spooled A nitrous fogger system. (any ideas how big i should go?) I am in the process of in stalling coil overs all the way around 250lbs/in in the front and 175lbs/in in the rear and a new rear sway bar |
| Poster |
Thread |
| TnPshow |
Posted: 2005/4/25 12:35 Updated: 2005/4/25 12:35 |
No life (a.k.a. DattoMaster)   Joined: 2002/8/22 From: Adelaide, SA Posts: 1991 |
 Re: GENERAL LEE A bigger picture would be good - let's see this beast up close! - or was this photo taken from a satellite?
| Poster |
Thread |
| COUP1200 |
Posted: 2005/4/25 12:51 Updated: 2005/4/25 12:51 |
Home away from home   Joined: 2004/12/8 From: Warburton vic Posts: 467 |
 Re: GENERAL LEE
| Poster |
Thread |
| General |
Posted: 2005/4/25 17:46 Updated: 2005/4/25 17:46 |
Not too shy to talk   Joined: 2005/3/15 From: Grapeview, WA. Posts: 37 |
 Re: GENERAL LEE This picture was acctually alot bigger. But in order to shrink the file size the picture became so small you need a magnifing glass to see it. Does anyone know how to shrink the file size without shrinking the picture?
I am taking it to the track for the first time this friday. I will update "ya all" on what she can do. Tomarrow I am installing my newly recurved distributor. That should help out a bit.
I just finished my suspension. I cant believe how tight the car handles now. I am very pleased.
| Poster |
Thread |
| tens_and_twenties |
Posted: 2005/4/26 3:54 Updated: 2005/4/26 3:54 |
No life (a.k.a. DattoMaster)   Joined: 2001/10/15 From: Arlington, TX, USA Posts: 1305 |
 Re: GENERAL LEE Quote: anyone know how to shrink the file size without shrinking the picture? Yeah, email me the big one and I will handle it for you. john@roper-photo.com
| Poster |
Thread |
| General |
Posted: 2005/4/26 4:24 Updated: 2005/4/26 4:24 |
 Re: GENERAL LEE damn. Im sorry I was just diggin in my files I cant seem to find it. Ill keep looking though. I do know that they are 3.0685" in dia and the piston weights 253.5g I found this info on my balance sheet. During install my buddy and I broke an ring and had to reorder one. The part number was JE XC78 or JE XC7800 I believe. I hope that helps.
| Poster |
Thread |
| B110SSS |
Posted: 2005/4/27 4:48 Updated: 2005/4/27 4:48 |
Home away from home   Joined: 2003/7/11 From: Posts: 490 |
 Re: GENERAL LEE General, I would be very interested in finding out more about these J&E pistons. Can you tell me who you bought them from and how much? Are they forged or cast? Was there an appreciable difference in the motors performance once you fitted them- assuming that you made no other mods at the same time? Cheers Dave
| Poster |
Thread |
| General |
Posted: 2005/4/27 20:13 Updated: 2005/4/27 20:13 |
 Re: GENERAL LEE I purchased the pistons from the late Malvern Racing. I believe that i payed about $550 for all four pistons, rings and pins. They are full floating and forged. When i fitted them I also fitted everything else at the same time. damn near quadrupled the power (estimating). I have not yet dynoed it. Do a search in yahoo or something for JE forged pistons, get there number and ask them. They should be able to help you more than I could about the specs of the pistons. I have mislocated my spec sheet. Sorry
| Poster |
Thread |
| datsa73 |
Posted: 2005/4/28 7:12 Updated: 2005/4/28 7:12 |
No life (a.k.a. DattoMaster)   Joined: 2000/1/10 From: Snohomish, WA USA Posts: 1287 |
 Re: GENERAL LEE Would like to meet up. I live north of Seattle. Let me know.
| Poster |
Thread |
| General |
Posted: 2005/4/28 15:29 Updated: 2005/4/28 15:29 |
 Re: GENERAL LEE Heck I wouldnt mind. Just need to find the time. Ill be at Bremerton race way tomarrow night (weather permiting). And the next I may be in Elma watching my buddy in his sprint car.
| Poster |
Thread |
| datsa73 |
Posted: 2005/4/28 19:17 Updated: 2005/4/28 19:17 |
 Re: GENERAL LEE I'll be at Evergreen Speedway Saturday night but they won't let me run my car unless I am willing to put a few dents in it. I help out with the Ambulance Crew. Looks like your runin' close to the same stuff I have in my 1973. I have the Electronic Ing. but am not using the MSN. Compressions not quit 11:1 only because I had plans for a turbo. I instead went with dual 32/36 down drafts. 279 duration cam from Delta Cam. It will easily run 9000rpm. Have to do a road trip south to your area.
| Poster |
Thread |
| General |
Posted: 2005/4/30 15:51 Updated: 2005/4/30 15:51 |
 Re: GENERAL LEE Yea thatd be great. I went to Bremerton raceway last night, but it was raining and the track was closed. oh well maybee another day. Im sure mine would run to 9000 as well, ive been to nervous to do that yet. i will though. ive only got it to 8000 while doing a burn out. kinda scared me. lol. we should drag. it would be close.
| Poster |
Thread |
| ddgonzal |
Posted: 2005/4/26 5:23 Updated: 2005/4/26 5:23 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31851 |
 Re: GENERAL LEE Quote: Does anyone know how to shrink the file size without shrinking the picture? Yes, details are here: How Can I post larger ImagesI would love to see a picture of this car. Where is Grapevine? How far from Seattle?
| Poster |
Thread |
| General |
Posted: 2005/4/26 6:13 Updated: 2005/4/26 6:13 |
 Re: GENERAL LEE Im about an hour and a half away from seattle. Im just south of Bremerton
| Poster |
Thread |
| LeDevil |
Posted: 2005/4/26 1:26 Updated: 2005/4/26 1:26 |
Just can't stay away   Joined: 2004/10/15 From: Vancouver, Wa Posts: 102 |
 Re: GENERAL LEE Haha, I saw you about a week ago in Shelton I was going to the court to pay a ticket. I tryed to flag you down but you didnt stop.
| Poster |
Thread |
| General |
Posted: 2005/4/26 3:07 Updated: 2005/4/26 3:07 |
 Re: GENERAL LEE LOL, Thats funny. Sorry I didnt notice. As you could emagine I have alot of people waving and honking there horns at me. Its quite a crack up. I even have the dixie horn that was on the general lee as well.
| Poster |
Thread |
| 2332owner |
Posted: 2005/4/26 3:35 Updated: 2005/4/26 3:35 |
No life (a.k.a. DattoMaster)   Joined: 2003/5/5 From: Okinawa, Japan Posts: 1292 |
 Re: GENERAL LEE I'm interested in the spec sheet and pricing of the pistons. Looks like you've got a fun car there... you can email me the pics and I'll resize them for you if you want.
