Main : Misc engine bay
[<   Previous  5424  5425  5426  5427  5428  5429  5430  Next   >]
engine bay
engine bayPopular
SubmitterGeneralMore Photos from General   Last Update2005/4/25 7:02    Tell a friendTell a friend
Hits2040  Comments4    0.00 (0 votes)0.00 (0 votes)
my engine bay
Dodgeman
Posted: 2005/4/26 5:31  Updated: 2005/4/26 5:31
 Re: engine bay
If you are running a diusc & drum brake system, you will need a dual circuit master cylinder. The single circuit cylinder with disc /drum brakes will only bring you grief.
General
Posted: 2005/4/26 6:19  Updated: 2005/4/26 6:19
Not too shy to talk
 Re: engine bay
In the near future I plan on converting the rear to disk brakes. I plan on using a rear end from a 79-83 200sx. I believe they are a H190. Im still looking for an affordable lsd or a locker set up. I hope to also purchase the other master cylinder with dual outlets. Thank you for your concern.
tens_and_twenties
Posted: 2005/4/26 4:05  Updated: 2005/4/26 4:05
 Re: engine bay
What's up with that brake master cylinder? Is that something from a Chevy?
General
Posted: 2005/4/26 4:33  Updated: 2005/4/26 4:33
Not too shy to talk
 Re: engine bay
Its actually a Willwood master cylinder. Part number WIL-260-6766. The carbs hit my power booster so i had to make it manual brakes. It works just great. The only problem is that it is a single outlet. Just as i finished installing it Willwood came out with the same style master cylinder but with dual outlet.
