[< Previous 1114 1115 1116 1117 1118 1119 1120 Next >]
New Panels
Coops 2005/5/2 23:13 Tell a friend
3156 2 0.00 (0 votes)
New Quarter panel & Sill panel out of Taiwan. Quarter - $240, Sill - $60. The Quarter panel needed a bit of massaging as it wasn't quite a perfect fit, but the sill panel fitted perfectly. P.S - The bullet hole's aren't real........YET! |
| Poster |
Thread |
| 1200rallycar |
Posted: 2005/5/3 3:41 Updated: 2005/5/3 3:41 |
No life (a.k.a. DattoMaster)   Joined: 2002/3/20 From: Melbourne, Australia Posts: 8221 |
 Re: New Panels whats involved in changing the sills, ive been wanting to do that for ages, but not sure what i actually need to do to change em
| Poster |
Thread |
| Coops |
Posted: 2005/5/3 6:35 Updated: 2005/5/3 6:35 |
Home away from home   Joined: 2004/8/14 From: Bris-Vegas Posts: 726 |
 Re: New Panels To change the sill panels you need to either grind or drill the spot welds out of the surrounding sheet metal. I would suggest a drill (either a store-bought spot weld drill or a sheet metal grind on a normal drill) as the holes will need to be repaired at some stage...... If you slip with the grinder things can get pretty messy. Then it's a matter of pulling out the old panel, inserting the new one & welding back in place (I used an oxy set). Be Warned! - There is lot of work involved in just replacing the panel, if you add everyone's little friend rust into the equation, things get a whole lot more complicated. Good Luck.
