Main : Members : 120fly my new tubo manifold
[<   Previous  1  2  3  4  5  6  7
my new tubo manifoldPopular
Submitter120flyMore Photos from 120fly   Last Update2005/5/23 7:38    Tell a friendTell a friend
Hits3504  Comments4    0.00 (0 votes)0.00 (0 votes)
After being unsuccesful with my other manifold and unable to weld the cast manifold to the steam pipe ,I decided to start all over again this is it so far ..
120fly
Posted: 2005/5/23 7:54  Updated: 2005/5/23 7:54
 Re: my new tubo manifold
some of you would of seen my other turbo set up i was building but iwas very unsuccesful in welding the cast manifold .
so this is what ive come up with so far i will be working on the intake manifold this weak and i will post som more pics
1200rallycar
Posted: 2005/5/23 10:32  Updated: 2005/5/23 10:32
hey buddy, this manifold plate thing was similar to what the first manifold i started with had
just wondering if your planning to use it as one piece like that or cutting it out,
i ended up cutting out the inlet sections on mine which i think would be beneficial, especially in my case becuase of the injector alignment
120fly
Posted: 2005/5/23 10:53  Updated: 2005/5/23 10:53
No i wont be cutting it out as its a draw through set up on this one , im also doing a set up similar to yours and with the camira injection as i have another plate cut im also putting in some time studying the kalmaker site and the delco 808 and ive leart some intresting things...
one question you could answer is .
Does the delco 808 run a crank angle sensor or does it run off the distributor once modified thats one thing thats got me stuffed
1200rallycar
Posted: 2005/5/24 16:19  Updated: 2005/5/24 16:19
i have a factory electronic dizzy (got through US can get more), i welded up the mechanical advance which is quite simple to see how to do if you pull the guts out, cut the wires on the module and put in the camira module in its place, and then plug the loom straight in and shes all good to go, only problem is polarity of wires which you have to guess, if you get it wrong you wont get spark so just have to flip em
(the wires im talking bout go from the module to the pick up inside the dizzy itself)
i also used the camira coil for same reason, loom plugs straight up to it
