Main : Members : evilsim air horns ~ velocity stacks
[<   Previous  14  15  16  17  18  19  20  Next   >]
air horns ~ velocity stacksPopular
SubmitterevilsimMore Photos from evilsim   Last Update2005/7/6 16:33    Tell a friendTell a friend
Hits2732  Comments4    0.00 (0 votes)0.00 (0 votes)
i won 4 of these 30mm horns on ebay and had them in 5 days from germany!! ended up being $20 a horn. they fit (too) snuggly under the K&N filter box so im going to diy an airbox with the use of an A series rocker cover. all installed now. sound is slightly throatier and after a quick mixture tune it was running happier than ever.. the air horns are made of aircraft grade alum and are machined and honed to perfection.
evilsim
Posted: 2005/7/6 16:41  Updated: 2005/7/6 16:41
 Re: wanted : A series rocker cover
edit: the airfilter ill be using for the diy airbox will be a large weber sock held within the piping.
p.s. if youve got a spare A series rocker cover and your in sydney msg me and ill give u $ for it!
sidedraught
Posted: 2005/7/6 23:24  Updated: 2005/7/6 23:24
I dont think you will get enough airflow through a single weber sock.
maybe a pod filter on the end of the airbox or individual socks.
I run mine without any filters because I love the look of the alloy trumpets.
BACKFIRE
Posted: 2005/7/7 3:58  Updated: 2005/7/7 3:58
Nice use of lightsaber. You have clearly mastered your full potentual of the force...
The filter on the single sidedraught practically touches the strut tower so there is no scope for messing about with it.
sidedraught
Posted: 2005/7/7 5:27  Updated: 2005/7/7 5:27
Ahh strut towers...... after 19 years of KB10 ownership I had nearly forgotten about the joys of 1200 ownership.
datsun_guy
Posted: 2005/12/31 11:15  Updated: 2005/12/31 11:15
iv goten the specs for a set of air horns and turnd them on a metal lath and it cost about $30 for all the metal and they work just fine i love the sound they make thhhhuq
dattodevil
Posted: 2005/12/31 22:06  Updated: 2005/12/31 22:06
Are you using the large or small K&N filter with those?
evilsim
Posted: 2006/1/1 12:24  Updated: 2006/1/1 12:24
small ones. the filters are covered with a custom unifilter wrap-around foam element which works well when im driving in dusty places.. im replacing with a custom airbox someone gave me.
