Main : Misc Bushes
[<   Previous  5057  5058  5059  5060  5061  5062  5063  Next   >]
Bushes
BushesPopular
Submitterdatrat_daveMore Photos from datrat_dave   Last Update2005/9/5 13:35    Tell a friendTell a friend
Hits2652  Comments3    0.00 (0 votes)0.00 (0 votes)
Tension rod, idler arm, sway bar link, lower arm and sway bar chassis mount. (from left to right)
All up cost me $102.30 from Bursons Auto.
datrat_dave
Posted: 2005/9/5 13:33  Updated: 2005/9/5 13:33
 Re: Bushes
My only worry is that the tension rod pack did not come with any crush tubes and my exsisting ones are cracked and broken.
I rang Bursons and they said not to worry to much as the factory rubber ones needed the crush tube as they flexed considerably - polyurethane ones do not and are MUCH stiffer ( i can hardly push them down!) But if the exisisting tubes can be used they advised me to use them.
What you guys reckon, it wouldn't matter that much as not to use them would it? I trial fitted them and they dont move around on the tension rod shaft too much so its not worrying me too much, just good to get some other input.
Cheers
Dave
datman55
Posted: 2005/9/5 14:05  Updated: 2005/9/5 14:05
 Re: Bushes
When you say tension rod, I assume you are talking about the radius rod (runs from front of chassis to the lower conrol arm) otherwise known as a castor rod.
If this is the case, I would not be using them without the inner tube, they are there for a reason. The fact that the guys at Bursons even suggested you use them if you could says it all....... Also, The bushes would be rubbing against the threaded section on the radius rod, that can't be good for longevity
I sell the Noltec brand of bushes, and I can tell you that they come with the metal inserts. Use the old ones....they are there for a reason, you should continue to use them.
datrat_dave
Posted: 2005/9/6 9:08  Updated: 2005/9/6 9:08
 Re: Bushes
And yes i am talking about the tension/castor/radius rod - many different names!
I dont see why this pack didnt come with the tubes tho, the trailing (upper and lower) both had them and so does the lower control arm... Why not the tension rod pack?!
Maybe there was a mix up in packaging or they just dont come with them, i aint sure but i will try and use the stuffed tubes....
Another thing, the boots on my ball joints (steering and knuckle arm) are completeley fraed and stuffed (all sticky and can pull them off), can i just use some rubber and replace the boot instead of replacing the whole ball joint?
Im not wanting to fork out $68 a ball joint!
Cheers Datman
Dave
oh and roughly how much are the bushes (if i get them thru you) the ones mentioned above? Noltec brand tho...
tom210
Posted: 2005/9/6 10:30  Updated: 2005/9/6 10:30
 Re: Bushes
im getting my balljoints done this week at Flemings in holbrook st next to the VW place, dad knows the fella so its all good, im hoping for about 250-300 bucks for all teh joints and sh!t so yeah, but after its registered the suspension will get a major work over, swaybar, adjustable shocks, might even get some slotted rotors $272 IIRC from supercheap so yeah. will be wicked
