Main : Misc : Forum water/methanol injection for suckthrough turbo
[<   Previous  439  440  441  442  443  444  445  Next   >]
water/methanol injection for suckthrough turboPopular
Submitter120flyMore Photos from 120fly   Last Update2005/9/10 4:48    Tell a friendTell a friend
Hits2821  Comments4    0.00 (0 votes)0.00 (0 votes)
My injection in action in a dummy set up to show you how they work inside the filter .
120fly
Posted: 2005/9/10 5:07  Updated: 2005/9/10 5:07
 Re: water/methanol injection for suckthrough turbo
With a bit more thought i came up with the idea of using a 6.5 litre weed sprayer .
this gives me a reservoir the ajustable nozzle .I shall remove the pressure release valve and connect a line from the +boost side with a one way valve .
Freak
Posted: 2005/9/10 5:43  Updated: 2005/9/10 5:43
I thought for water injection to cool properly it would have to be injected into the manifold just before the ports so it cooling the already atomised fuel/air mixture. Just like NOS. I have never seen it been injected inside the airfilter probably because it wouldnt be very effective. Maybe you could drill a hole in where the two runners join on the manifold, tap a thread and screw water injectors in. 1 injector for 2 ports.
120fly
Posted: 2005/9/10 6:22  Updated: 2005/9/10 6:22
The system is quit efective actually for a suck through .The theory is that the methanol is sprayed into the su upon boost
and drawn through the turbo and atomised
with the fuel .This creates a richer mix on boost and helps with detonation .
NickZ
Posted: 2005/9/10 6:39  Updated: 2005/9/10 6:39
Not too shy to talk
This system works very effectively. I have run the same type of system no a few of my turbo drawthrough setups.
I not only cools the air fuel mixture but also cools the compressor wheel and that helps it atomise also, I would think it would be more efective then just firing into the ports near the head as it wont atomise as well.
But there is a problem with this system, water WILL pitt the compressor wheel over time and over time wear out the turbo faster.
