Main : Misc : Forum Dyno result from powercruise 2005 dyno
[<   Previous  422  423  424  425  426  427  428  Next   >]
Dyno result from powercruise 2005 dynoPopular
Submitter120flyMore Photos from 120fly   Last Update2005/10/15 10:54    Tell a friendTell a friend
Hits3324  Comments3    0.00 (0 votes)0.00 (0 votes)
The results from my 120y a12 with a14 head and turbo  set up running about 5psi boost
Posted: 2005/10/15 18:35  Updated: 2005/10/15 18:35
 Re: Dyno result from powercruise 2005 dyno
70 hp sounds good for an A12. That's probably 100 hp at the flywheel (where car manufacturers rate hp). From only 1.2 liters ...
Nissan4Eva
Posted: 2005/10/19 1:21  Updated: 2005/10/19 1:21
thats about a 30hp increase with 5psi... not bad.
why did u lower the compression by using the A14 head??
Wouldn't the standard 9:1 cr been good enough for 10-si??
120fly
Posted: 2005/10/19 6:21  Updated: 2005/10/19 6:21
Honestly we put the a14 head on the origanal 120y a12 with the turbo set up .
All is basically standars .This was a test run to see what it would produce ,We will rebuild it and hope we can produce At least 150 HP at the fly wheel for next years powercruise
