Main : Misc Dowled A14 Crank
[<   Previous  5002  5003  5004  5005  5006  5007  5008  Next   >]
Dowled A14 Crank
Dowled A14 CrankPopular
SubmitterCOUP1200More Photos from COUP1200   Last Update2005/10/17 1:33    Tell a friendTell a friend
Hits2698  Comments2    0.00 (0 votes)0.00 (0 votes)
The crank shaft in my A14
kegs
Posted: 2005/10/17 8:18  Updated: 2005/10/17 8:18
 Re: Dowled A14 Crank
the dowel is to stop the flywheel turning on the crank at high rpm exceeding 8000rpm, usually with a stock crank the holes in the flywheel are only clearance holes so there can be movement between the bolts and flywheel.the dowel makes it so the dowel takes up the movement and makes the bolts only hold the flywheel on, and not stop the flywheel moving.
hotrod88
Posted: 2005/10/17 5:29  Updated: 2005/10/17 5:29
very out of focus, what is the purpose of the dowel may I ask?
