Main : Misc My New Injin
[<   Previous  4982  4983  4984  4985  4986  4987  4988  Next   >]
My New Injin
My New InjinPopular
SubmitterconvertedMore Photos from converted   Last Update2005/10/27 19:00    Tell a friendTell a friend
Hits4922  Comments20    0.00 (0 votes)0.00 (0 votes)
Here is my new SR20 stock S13 at moment but have just fitted 50mm quad throttle bodies...will have porting by Jeff Taylor, cams, lash kit, adj cam pulleys, 12.5mm lift cams and still havent decided what ECU to run...
took about 40kgs worth of crap off it though...
REDZ
Posted: 2005/12/10 3:38  Updated: 2005/12/10 3:38
 Re: My New Injin
I run this same setup in my ute.. But there 45's not 50's....Makes 130 atw with a VERY flat torque curve only onther mods are custom extractors and changed the cam timing..
Has run 13.85 at 98mph on street ruber...
Form those that are wondering clearence in not an issue.... Aside from where you possition your clutch master..
I also run longer trumpets than those supplied and they did interfier with the structurial support on the bonnet...
PS. Make sure you have a good tuner cause the guys that did mine did a #### job, bad idle surges when cruising...
ca18det_man
Posted: 2005/10/29 12:33  Updated: 2005/10/29 12:33
 Re: My New Injin
very noice how long till its running?? will she be go for bathurst??
converted
Posted: 2005/10/30 2:48  Updated: 2005/10/30 2:48
 Re: My New Injin
maybe not bathurst, Andrew that would be a push. Maybe Feb '06 so i can do some testing and be ready for rnd 1 at Wakefield
DattoChrisUte
Posted: 2005/11/14 6:15  Updated: 2005/11/14 6:15
Not too shy to talk
 Re: My New Injin
Do those kits use factory sr20 injectors. or do you have buy injectors off efi tech.
converted
Posted: 2005/11/14 6:30  Updated: 2005/11/14 6:30
 Re: My New Injin
It has S15 200SX injectors in the new rail. Flows a bit more that stock injectors
nick_m
Posted: 2005/11/15 23:21  Updated: 2005/11/15 23:21
 Re: My New Injin
Hey, when you say a lash kit do you mean convert to solid lifters or run rocker arm stoppers? Also what cams do you plan on running. I'm pretty interested to see how this all turns out so make sure you do heaps of updates :)
cheers
Nick
converted
Posted: 2005/11/16 1:26  Updated: 2005/11/16 1:26
 Re: My New Injin
Nick just rocker stoppers at this stage.
Stage 1 I will run completely stock motor apart from throttle bodies, programmable ECU and custom extractors.
I hoping with fingers crossed for 140hp at the wheels but with alot more torque and drivablility out of corners. Thats where I lose most time on the track.
Stage 2 will be working on the head ...porting cams springs etc etc to increase to maye 160rwhp with stock bottom end.
The best you could ever hope out of an injected A15 1600cc would be 125rwhp.
My main advantage will be weight as the coupe should weigh in at 850kg dry.
nick_m
Posted: 2005/11/16 2:39  Updated: 2005/11/16 2:39
 Re: My New Injin
wicked i'm toying with the idea as well which is why im interested to see how you get on. I would have thought the 50's (Quad Throttle Bodies) would have been to big especially with the std cams. I'll probably go 48's, the tomei sr20de crate engines make 265ps (@ engine) with 48's so thats good enough for me! :)
If you decide to rebuild the bottom end non turbo 300zx pistons will fit with a little bit of modification, and i'm led to believe they give a 11:1 comp with a std combustion chamber and still have big enough valve reliefs to run some pretty decent cams.
Cheers
Nick
dattoman_1000
Posted: 2005/10/28 6:43  Updated: 2005/10/28 6:43
 Re: My New Injin
I am thinking of SR power for my little rocket in years to come
Can you do some measurements for me so I can see if it will fit mine
I need the width from centre of head to widest point on both sides of engine... including those pretty T/B's you have there as I was thinking of using those too.
I'd also like to know the legth of the engine and also the length of the box
I think this is the way to go in the future..... as you say in stock form this engine takes up where the old relable A leaves off
converted
Posted: 2005/10/28 9:55  Updated: 2005/10/28 9:55
 Re: My New Injin
ok i will get for you soon...
teretonga
Posted: 2005/10/28 14:32  Updated: 2005/10/28 14:32
 Re: My New Injin
Have you got my tape measure there as well? I can't find it...
Mr_Turbo
Posted: 2005/10/29 1:13  Updated: 2005/10/29 1:13
 Re: My New Injin
where u get those quad throttle body's off? gti-r?
and last time i seen u, u were talking up the old a15 like it was a jet motor haha
how much power u aiming for from the n/a sr20? considering they come 108kw stock
Grunterhunter
Posted: 2005/10/29 3:18  Updated: 2005/10/29 3:18
 Re: My New Injin
The rwd version should have 119kW and 188nM. A bit more grunt- say 125-130 kW and i reckon it would be an almost perfect choice for a daily driver- enough grunt to keep the v8's honest and 8L/100 fuel econ. only real downside is their weight.
converted
Posted: 2005/10/27 19:04  Updated: 2005/10/27 19:04
 Re: My New Injin
the a series had to go....but this engine stock is where my last engine left off...only fun from here...
teretonga
Posted: 2005/10/27 19:22  Updated: 2005/10/27 19:22
 Re: My New Injin
Looks great already Watto... wait a minute I'll be right over for me floor jack and spotlight. I couldn't find them anywhere.
converted
Posted: 2005/10/27 19:34  Updated: 2005/10/27 19:34
 Re: My New Injin
while youre there bring bessie back
teretonga
Posted: 2005/10/27 19:42  Updated: 2005/10/27 19:42
 Re: My New Injin
nah she is assisting the FBI with their door - to - door enquiries over here...
nzdatman
Posted: 2005/10/29 3:23  Updated: 2005/10/29 3:23
 Re: My New Injin
looking good Craig. What gearbox are you going to use? What box did you use behind the A? Have you weighed the engine to see what they weigh minus all the crap?
kegs
Posted: 2005/10/29 4:57  Updated: 2005/10/29 4:57
 Re: My New Injin
i doubt a gti-r comes with 50mm t/b's like them,maybe 35mm.... they look like twm induction t/b's or injection perfection or something ????
converted
Posted: 2005/10/29 11:24  Updated: 2005/10/29 11:24
 Re: My New Injin
gearbox will be a R32 GTS-T box with an SR20 adaptorbellhousing.
The throttles are from EFI Hardware
EFI Hardware / Speed technology.
