Main : Members : Wogboy bottom raditor mounting pannell
[<   Previous  32  33  34  35  36  37  38  Next   >]
bottom raditor mounting pannellPopular
SubmitterWogboyMore Photos from Wogboy   Last Update2005/12/28 19:12    Tell a friendTell a friend
Hits2203  Comments3    0.00 (0 votes)0.00 (0 votes)
it bolts in with 4 m6 bolts so that it's easy to remove the motor
Wogboy
Posted: 2005/12/21 10:44  Updated: 2005/12/21 10:44
 Re: bottom raditor mounting pannell
LAGWAGON
I was hoping it would be ready by XMAS but it wont be may be a few more months as I still have to
get a fuel tank made
make all the fuel lines
hand brake cable
battery box
full interior
raditor hoses
clutch mechanism
full wire up
and a few little other things
As for the fabrication side of things I make as much as I can and what I cant I get it made for me as I dont have a press
dattodude the thermo fan is going behind the raditor on the passanger side have to make a little alloy shroud for it,as it will just fit there because I've left enough room between the intercooler and the raditor for a air con condensor but thats later on down the track after I get it going
LAGWAGON
Posted: 2005/12/20 21:28  Updated: 2005/12/20 21:28
that is very cool. are you doing all the fabrication work yourself? How close are you to starting it and having a drive?
dattodude
Posted: 2005/12/20 22:51  Updated: 2005/12/20 22:51
From my experiences, where are the radiator fans going?
It is looking good though. Keep it up!
