[< Previous 4094 4095 4096 4097 4098 4099 4100 Next >]
| Poster |
Thread |
| kegs |
Posted: 2005/12/22 6:26 Updated: 2005/12/22 6:26 |
No life (a.k.a. DattoMaster)   Joined: 2003/1/5 From: campbelltown (sydney) australia Posts: 1802 |
 Re: front gaurd mods for bigger tyres if you put 50 series tyres youd fit em easily, my wheels dont rub on the guards and ive got 15's....
| Poster |
Thread |
| Ronald |
Posted: 2005/12/22 6:58 Updated: 2005/12/22 6:58 |
Home away from home   Joined: 2005/12/7 From: Bendigo, Victoria, Australia. Posts: 781 |
 Re: front gaurd mods for bigger tyres wot series u got on ur 15"s?
| Poster |
Thread |
| L18_B110 |
Posted: 2005/12/22 7:57 Updated: 2005/12/22 7:57 |
No life (a.k.a. DattoMaster)   Joined: 2002/8/6 From: Brisbane, Australia Posts: 3792 |
 Re: front gaurd mods for bigger tyres 50 series aren't exactly common in 14". I have had a set or 195/55*14" Yokohamas that i got brand new from an importer, but they required a bit of pumping of the gaurd as well as lipping.
So I imagine a 195/50*15" would also. 195/50*15" are the same OD as the 185/60*14 pictured, so unless you have standard 1200 front end, i can't really see how you got them in without any mods to the gaurds.
I had adjustable castor rods at the time too, with a bit of extra castor wound on. But I seem to recall having to trim the front of the wheelarch even when I first put it all together with a 175/60*14 and the stanza front end and no adjustment on the castor rods - but you do get a bit of extra castor with the Stanza conversion due to the longer control arms anyway.
| Poster |
Thread |
| matty |
Posted: 2005/12/22 14:02 Updated: 2005/12/22 14:02 |
No life (a.k.a. DattoMaster)   Joined: 2003/3/28 From: brisbane Posts: 1880 |
 Re: front gaurd mods for bigger tyres As has been mentioned 185/60R14 and 195/50R15 are virtually identical in rolling diameter. What makes cutting the guards necessary is the extra castor. I run the same size rubber and they fitted without any rubbing till I installed adjustable castor rods. Regards Matty
| Poster |
Thread |
| hotrod88 |
Posted: 2005/12/24 0:04 Updated: 2005/12/24 0:04 |
Home away from home   Joined: 2005/6/20 From: Alabama, U.S.A. Posts: 522 |
 Re: front gaurd mods for bigger tyres I am running 195x60R14 and have no probs. with the stock front end.
