Main : Members : 731200 All engineered now
[<   Previous  14  15  16  17  18  19  20  Next   >]
All engineered now
All engineered nowPopular
Submitter731200More Photos from 731200   Last Update2005/12/26 1:23    Tell a friendTell a friend
Hits2174  Comments13    0.00 (0 votes)0.00 (0 votes)
Had to be done for engeneering purposes
chris1200t
Posted: 2006/1/1 10:20  Updated: 2006/1/1 10:20
 Re: All engineered now
1 bar = 14.4 which i was told was double the atmospheric pressure. wot sorta turbo r u using and what has been done tot he internals?
kegs
Posted: 2006/1/1 11:50  Updated: 2006/1/1 11:50
1 bar IS atmospheric pressure, thats why sometimes u hear people say their car is running one atmosphere of boost above normal...
Posted: 2006/1/5 9:04  Updated: 2006/1/5 9:04
Using a rx7 series3 turbo dished pistons o-ringed block slightly decompressed.
ooooooooooooooooooilleagal!!!!!!!!!!!!!!!!!!!!
i bet i could defect 9/10 cars on the road even some new ones.......some of those rules are stupid!!
kegs
Posted: 2006/1/5 11:50  Updated: 2006/1/5 11:50
sorry timo ur right it can vent to atmo, but i think if a cop hears ur car not venting air then they wouldnt know the diff, depending where u live cops may or may not have been around and seen the new fandangle things us young people have on our cars these days.
Posted: 2005/12/26 1:35  Updated: 2005/12/26 1:35
the recirculating BOV and that cover over the airfilter make it legal.......they didnt even look at engine mounts or anything......the engine could fall out but thats ok cause it has a cover over the airfilter!!!!!!!lol
120fly
Posted: 2005/12/26 1:43  Updated: 2005/12/26 1:43
Well done simplicity is often the best
could you please explain whats been done to the carby to hold boost ....So many people hear wanting to do the same maybe you could pass on a bit of info as no one has really gone into deepth about it cheers
Posted: 2005/12/26 2:08  Updated: 2005/12/26 2:08
As far as i know its just a webber 32/36 downdraft with a hat over the top(like a little plenum) there is nothing changed inside the carb except for changing the jets to suit the engine and fill the float with spongerez (floaty foam stuff so your float dosent crush under boost).
The real crutial thing is the rising rate fuel pressure regulator without that nothing would work.
And dont get to greedy with boost 1 bar is plenty, you would have to box the carb to go more boost i think.
MadTimo
Posted: 2005/12/26 5:11  Updated: 2005/12/26 5:11
but I can clearly see that the BOV vents to atmosphere
1200rallycar
Posted: 2005/12/26 23:06  Updated: 2005/12/26 23:06
1 bar is plenty!!!!!!!!!!!!!!!!!
i had 3 32/36s on my setup running less than 10psi boost, none of them held gaskets in at all
dattodude
Posted: 2005/12/27 10:54  Updated: 2005/12/27 10:54
It recirculates after bouncing off the underneath of the bonnet and back into the pod filter
1 bar would hoot!
Posted: 2005/12/29 3:34  Updated: 2005/12/29 3:34
1 bar is about 14 pounds, right? I thought popular wisdom is these carbs will safely only handle 5 pound boost, any more than that and they should be boxed.
kegs
Posted: 2005/12/29 3:58  Updated: 2005/12/29 3:58
the bov has a atmo and recirc 2 way system so u can choose what u want by turning the top of the bov.
Posted: 2005/12/31 16:11  Updated: 2005/12/31 16:11
yeah i think 1 bar is about 15psi........it works sweet maybe the carb is glued togeather or something
someone also told me there are turbo 32/36 carbs but not sure if its true.
MadTimo
Posted: 2006/1/1 13:33  Updated: 2006/1/1 13:33
Yes, but it CAN vent into atmosphere....which I got told is illegal
