Main : Mechanical : Drive Train Help Need with Info on Diff
[<   Previous  612  613  614  615  616  617  618  Next   >]
Help Need with Info on DiffPopular
SubmitterDatoRacerMore Photos from DatoRacer   Last Update2006/3/8 7:10    Tell a friendTell a friend
Hits2188  Comments4    0.00 (0 votes)0.00 (0 votes)
Hi All, This is the diff head out of my 1200 Coupe circuit car. To date i have never need to know what it was out of, until now, when a foreign object has destroyed the crown wheel and pinon. I have read the tech section and i am still confused. The housing is Aloy, it has a od of 185mm. The crown wheel measures 145mm od. It has 37.9 stamped on it beside the datsun symbol, then PS44.2, It also has the smaller of the two drive shaft flanges. Any ideas of what it may be out of, Or any surgestions on what i could use to adapt into the aloy housing.
stirlingmac
Posted: 2006/3/9 0:08  Updated: 2006/3/9 0:08
 Re: Help Need with Info on Diff
Hi Paul, I reckon you've got a standard type 1200 wagon diff head and gears...4:1.1. The wagons had the alloy head. Hope your'e looking after that baby down there and remember if it ever needs a new home call me first....
b310gx
Posted: 2006/3/8 10:28  Updated: 2006/3/8 10:28
yes,the studs holding the bearing caps onto the housing shows it's from a 1000.the 1200 h145's have bolts instead.
Posted: 2006/3/8 22:57  Updated: 2006/3/8 22:57
Since the ring gear is 145 mm and it says "Datsun", it must be an H145?
1200s have studs too. It's the H150 that has bolts.
H150
A14force
Posted: 2006/3/8 8:43  Updated: 2006/3/8 8:43
Didn't some of the 1000's have an alloy H145?
I have a couple of spare H145's.(Steel ones) PM me if you're interested.
