Main : Members : PIGDOG L series fitting
[<   Previous  173  174  175  176  177  178  179  Next   >]
L series fitting
L series fittingPopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2006/4/2 13:47    Tell a friendTell a friend
Hits2352  Comments5    0.00 (0 votes)0.00 (0 votes)
showing how much room i have infront and behind the engine
R-fastmotorsport
Posted: 2006/4/3 13:30  Updated: 2006/4/3 13:30
 Re: L series fitting
Looks like a looong way to go yet Good luck with the project - I hear 1200's are heaps of fun with the L20. Hope I find out soon!
Cheers
WhiteSedan
Posted: 2006/4/3 13:40  Updated: 2006/4/3 13:40
Mines at this stage too, ive got clutch m/c sorted and radiator, just have engine/gearbox mounts now + tailshaft, trying to get engine as low in the car as possible, im playing around with different sumps, looking for a 4x4 720 sump.
At least wiring is pretty much the same!
PIGDOG
Posted: 2006/4/4 9:39  Updated: 2006/4/4 9:39
this engine probably will never run in that car
i have the luxury of having 2 1200s, this one is full of rust, so it is the guinea pig, it gets the whole trans tunnel cut out so i can see how big the gearbox really is
ill be starting the search for a 4x4 720 sump soon, and also the gearbox
i modified the engine mounts on the engine a fair bit, now mount the engine 25mm lower and 30mm further forward than standard, had to mount it forward to get the engine mount stalks on the crossmember centred
then i found out that standard 180b engine mount things(ones that also bolt to engine) sit the engine at the same height as my modded ones
so basically im only using this car to make the crossmember in and figure out how to attack the trans tunnel
PIGDOG
Posted: 2006/4/4 9:41  Updated: 2006/4/4 9:41
also i found that if you are going for an L18 the 720 block is the one to get, as it has multiple dipstick holes
but that there is just the dummy engine in the dummy car
and wiring is ####e easy, i rewired my 200b so that it had all switches(ignition, starter, thermo and lights) on the dash in about half a day, running all new wires and fuses
i still have till september till the car has to be ready, so im not in any great hurry to get it finished
pitanando
Posted: 2006/4/3 13:11  Updated: 2006/4/3 13:11
nice! good job! do you stil have the a12 gear box on our is it another one?
converted
Posted: 2006/4/3 13:28  Updated: 2006/4/3 13:28
close to the size and clearance of the SR20 I just installed..its a big job good luck and dont lose heart.
