Main : Misc DiscoStu's Blown A14
[<   Previous  4672  4673  4674  4675  4676  4677  4678  Next   >]
DiscoStu's Blown A14Popular
SubmitterDiscoStuMore Photos from DiscoStu   Last Update2006/4/7 3:09    Tell a friendTell a friend
Hits4932  Comments23    0.00 (0 votes)0.00 (0 votes)
593 kg ute.  310hp
Grunterhunter
Posted: 2006/4/7 8:17  Updated: 2006/4/7 8:17
 Re: DiscoStu
a couple of questions for you stu- what pulley are you using on the flywheel? has it been made specially for the job or is it a combo of 4AGZE & A15?
Did you have any hassles with the dizzy or dipstick, mounting the blower over that side?
310hp implies some serious boost- do-able but stretching things a bit.
Assuming that that is an SC12 (I havn't seen enough of them to be sure) , and the motor is built for a 'N/A equivalent' of 130hp then by my calcs, you will need in the order of 20psi, a ratio of 1:1.47 on the blower(spinning to 10,300rpm) 450cfm of flow...... assuming 100% efficiency of the blower i.e 100hp n/a = 200 hp at 14.7 psi boost.
A14force
Posted: 2006/4/7 10:11  Updated: 2006/4/7 10:11
 Re: DiscoStu
Looks to me like an s/c14.
Is the carb a 350, or a 500? I've just upgraded mine to a 350 holley from a 32/36 weber. You may find that the standard 1/4 fuel line wont be able to keep up.
I hope you're planning to use silicon hose to join the pipes. A work of advise, afix a bracket of some decription to the tube which attaches to the blower disharge neck. My mates got an S/c12 on a rear drive 323 wagon. When it fires up and the blower starts to make a bit of heat, to blower tries to blow the pipe off. You really oughta tie it down. I'd bee quite interested as to what kind of rwhp it makes. I think we all are.
Supercharging is the shizzle, I should have mine going again tommorow with the new carb and fuel supply. There's drags at easter too. Can't wait.
Tommy
Posted: 2006/4/8 12:16  Updated: 2006/4/8 12:16
 Re: DiscoStu
i have sent an email 2 this mod in queanbeyan as i am also keen 4 sum engine work. and seein as though i live like 15mins away. may as well look into it. You where the guy who was doing the airbag conversion yea?m hows that going???
4NIK8
Posted: 2006/4/8 16:36  Updated: 2006/4/8 16:36
 Re: DiscoStu
looks great mate, keep it up
rb20
Posted: 2006/4/7 6:41  Updated: 2006/4/7 6:41
 Re: DiscoStu
i am running a simmilar set up but my charger will be on the oppisite side
i think the colour of your rocker cover is interesting is it panama green
before install
DiscoStu
Posted: 2006/4/7 6:59  Updated: 2006/4/7 6:59
 Re: DiscoStu
I'm actually going to change the Rocker Cover. I'm working on a Design to have the Word "DATSUN" written in Caligraphy then imposed on the cover. Not sure if I can do it yet but I'll give it a damn good try.
Tyrie
Posted: 2006/4/7 7:23  Updated: 2006/4/7 7:23
 Re: DiscoStu
I've got a rocker cover that doesnt have writing on it if ya want it, might be better for what you want to do...
sidedraught
Posted: 2006/4/7 7:27  Updated: 2006/4/7 7:27
 Re: DiscoStu
One of these would go nicely with your alloy work.
Ianey
Posted: 2006/4/7 7:30  Updated: 2006/4/7 7:30
 Re: DiscoStu
Whats your plan re the air filter?
rb20
Posted: 2006/4/8 9:15  Updated: 2006/4/8 9:15
 Re: DiscoStu
yea i just thaught it was an interesting choice of colour for a yellow car
Tommy
Posted: 2006/4/8 12:15  Updated: 2006/4/8 12:15
 Re: DiscoStu
sidedraught
Posted: 2006/4/7 3:56  Updated: 2006/4/7 3:56
 Re: DiscoStu
Great looking setup Stu, nice and simple.
310HP sounds optimistic, I will be interested to see how it goes.
How did you get the ute down to 593KG?
DiscoStu
Posted: 2006/4/7 3:59  Updated: 2006/4/7 3:59
 Re: DiscoStu
A Lot of time and effort with an angle grinder and welder.
sidedraught
Posted: 2006/4/7 4:03  Updated: 2006/4/7 4:03
 Re: DiscoStu
The workmanship is really first rate, did you do it yourself?
now that is something that you could sell as a kit.
DiscoStu
Posted: 2006/4/7 4:10  Updated: 2006/4/7 4:10
 Re: DiscoStu
Nah, Pro Engines in Queanbeyan (Just Outside Canberra) Did most of the work. Greg Tarlington and his team did a great Job on the motor but I've done all the rest. She's got copper gasket and bored out to take 1500 pistons. Blue Printed and Balanced. She's gonna be a mean streeter. What did you want to know about the horsepower?
sidedraught
Posted: 2006/4/7 4:15  Updated: 2006/4/7 4:15
 Re: DiscoStu
So Pro Engines reckon it will make 310 HP?
DiscoStu
Posted: 2006/4/7 4:25  Updated: 2006/4/7 4:25
 Re: DiscoStu
Yeah, 310+ but that's only at the FlyWheel.
Ianey
Posted: 2006/4/7 4:16  Updated: 2006/4/7 4:16
 Re: DiscoStu
What is happening with the 10mm gap between those pipes above the head? Its looking real mean
DiscoStu
Posted: 2006/4/7 4:26  Updated: 2006/4/7 4:26
 Re: DiscoStu
It's just an old photo. That gap has been joined and she's going on the Dyno this week to see how much HP it will produce.
Cable_Tie
Posted: 2006/4/7 4:37  Updated: 2006/4/7 4:37
 Re: DiscoStu
I'd like to see photo's of the belts.
What have you done with the drive pulley?
Dodgeman
Posted: 2006/4/7 4:43  Updated: 2006/4/7 4:43
 Re: DiscoStu
Poster: DiscoStu Date: 2006/4/7 14:10:06
How much did it need to be bored before the 1500 [A15?] pistons would fit?
DiscoStu
Posted: 2006/4/7 5:23  Updated: 2006/4/7 5:23
 Re: DiscoStu
3mm if I recall correctly, but I'll have to ask greg at Pro Engines to make sure.
Posted: 2006/4/8 17:38  Updated: 2006/4/8 17:38
 Re: DiscoStu
A15 and A14 have the same bore. It is 76mm compared to only 73mm for the A12.
By the way, the blower mounting looks nice. The curve of the bracket looks tough.
Grunterhunter
Posted: 2006/5/1 2:58  Updated: 2006/5/1 2:58
 Re: DiscoStu
Hey Stu, what's the word on mounting the blower upside down? Are you going to have any hassles with lubrication?
datman55
Posted: 2006/4/7 5:25  Updated: 2006/4/7 5:25
 Re: DiscoStu
Looks fantastic dude.... Hope all goes well on the dyno.
