Main : Mechanical : Suspension Strut Top Camber Adjuster
[<   Previous  394  395  396  397  398  399  400  Next   >]
Strut Top Camber AdjusterPopular
SubmittersssuteMore Photos from sssute   Last Update2006/4/10 14:21    Tell a friendTell a friend
Hits3626  Comments8    0.00 (0 votes)0.00 (0 votes)
Strut top I've been working on
sssute
Posted: 2006/4/11 17:13  Updated: 2006/4/11 17:13
 Re: Strut Top Camber Adjuster
steringmac, there are a seires of holes in the slots, so to increase camber u remove the bolts from two holes and slide the lower plate to position and re-fit bolts in the holes which line up.
sssute
Posted: 2006/4/11 17:06  Updated: 2006/4/11 17:06
Cable tie i am looking in to making them if i have intrest, they would be around the $400 mark depending how many i make
sssute
Posted: 2006/4/11 17:02  Updated: 2006/4/11 17:02
lemonhead ill get back to you with part number
stirlingmac
Posted: 2006/4/10 21:45  Updated: 2006/4/10 21:45
Nice work, but how do you change the camber when the 2 cap screws are at either end of the slots??
Lemonhead
Posted: 2006/4/10 23:27  Updated: 2006/4/10 23:27
Could you please post the part number of the bearing you are using in these units.
benddatsun
Posted: 2006/4/11 1:21  Updated: 2006/4/11 1:21
Yes a part # and make would be great.
Cable_Tie
Posted: 2006/4/11 1:46  Updated: 2006/4/11 1:46
Interested in going into production?
Approx cost?
converted
Posted: 2006/4/11 3:08  Updated: 2006/4/11 3:08
also its usually good to have some castor for high speed straight line stability
cheater_5
Posted: 2006/4/10 21:31  Updated: 2006/4/10 21:31
SWEEEEEEEEEEEET (drool)
UTE18L
Posted: 2006/4/10 16:04  Updated: 2006/4/10 16:04
Its sure got the looks.
