Main : Mechanical : Suspension Castor rod upgrade pic
[<   Previous  398  399  400  401  402  403  404  Next   >]
Castor rod upgrade picPopular
Submitter1200coupeMore Photos from 1200coupe   Last Update2006/5/9 11:16    Tell a friendTell a friend
Hits4218  Comments2    0.00 (0 votes)0.00 (0 votes)
This should help clear things up.
1200coupe
Posted: 2006/5/9 11:19  Updated: 2006/5/9 11:19
 Re: Castor rod upgrade pic
Here you go Dan, this pic shows the way the LJ castor Rods are fitted. I thought something looked different in your other pic
Anyway this is how I had to do it to make everything work for my setup.
Grunterhunter
Posted: 2006/5/13 10:16  Updated: 2006/5/13 10:16
Cool.
It looks like they have been modified.
they've cut the final hole off, and drilled one hole either side of the front hole to get the right angle. That was what I was thinking of doing If they wouldn't fit using the inner parallel holes.
