Main : Misc : Forum OLD SKOOL POWER
[<   Previous  365  366  367  368  369  370  371  Next   >]
OLD SKOOL POWER
OLD SKOOL POWERPopular
Submitter120flyMore Photos from 120fly   Last Update2006/5/11 10:55    Tell a friendTell a friend
Hits2139  Comments7    0.00 (0 votes)0.00 (0 votes)
Went to ipswich show today with the kids and dad still had time for a little horse power
Dodgeman
Posted: 2006/5/11 15:28  Updated: 2006/5/11 15:28
 Re: OLD SKOOL POWER
The coolant circulation was based on the good old, tried & true, 'thermo siphon' principal. Hot water from the top of the head rises & is replaced with cooler, & therefore heavier, water from the bottom of the drum.
It is important for the bottom of the drum to be at least level with the bottom of the coolant jacket, or a little higher. for it to establish an efficient circulation, & the top of the radiator, or coolant resevoir [drum] must be higher than the top of the engine &, within reason, the higher the better.
This engine has no separate cylinder head & the block & head are cast as one unit. The valves are accessed by removing the two large brass plugs in the head & one of these is made to accept the spark plug, which is usually placed over the exhaust valve, not the inlet as this one has.Quote:
Poster: rte38 Date: 2006/5/11 23:47:33
As long as that 44gal drum stayed full and heat evaporated the water slowly over a week
Bein' Diesel they ran hot but with that amount of water it was not a worry
It is a spark ignited engine, not a Diesel, as can be determined from the carburettor, the spark plug & the plug lead. It's also a 13 gallon drum, not a 44.
These things ran close to boiling when working hard, which was good because they ran on poor quality petrol or even Power Kerosene which needed quite some heat to make it vaporise properly & run well.
Early engines used an automatic exhaust valve actuation with an atmospheric inlet valve. Worked perfectly.
120fly
Posted: 2006/5/12 2:02  Updated: 2006/5/12 2:02
 Re: OLD SKOOL POWER
Ah very true dodgeman ,Yes the fuel they were using was very kerosine based a very thick fuel and the tanks were under 500mls and ran all day from what i was told ,It reminded me of the old diesel engines Ive had on the old control line planes
WhiteSedan
Posted: 2006/5/11 13:49  Updated: 2006/5/11 13:49
 Re: OLD SKOOL POWER
as it has no water pump is it gravity fed water??
120fly
Posted: 2006/5/11 11:09  Updated: 2006/5/11 11:09
 Re: OLD SKOOL POWER
Have a good look lads this is one of the first water cooled engines .The steel tub is the radiator and it has no water pump .
Can you guess how it works ?
sidedraught
Posted: 2006/5/11 11:44  Updated: 2006/5/11 11:44
 Re: OLD SKOOL POWER
I love this sort of gear, we had engines like this growing up on the farm,(actually not quite as primitive as this, but not far off it)
It was real "hands on" technology, where man and machine understood each other.
Anonymous
Posted: 2006/5/11 13:44  Updated: 2006/5/11 13:44
 Re: OLD SKOOL POWER
And some ass had the hide to complane about what i poast
Keep it up i love the old stuff,many a day in my early days i had to crank thease old things over
Anonymous
Posted: 2006/5/11 13:47  Updated: 2006/5/11 13:47
 Re: OLD SKOOL POWER
As long as that 44gal drum stayed full and heat evratored the warter slowely over a week
Been Deasil they ran hot but with that amount of warter it was not a worrie
