Main : Misc My 1200
[<   Previous  4361  4362  4363  4364  4365  4366  4367  Next   >]
My 1200
My 1200Popular
Submitteraca18tMore Photos from aca18t   Last Update2006/6/18 9:52    Tell a friendTell a friend
Hits2741  Comments7    0.00 (0 votes)0.00 (0 votes)
2 link fitted
killer1200
Posted: 2006/6/18 12:39  Updated: 2006/6/18 12:39
 Re: My 1200
Didnt want to use coilovers ?
LAGWAGON
Posted: 2006/8/29 3:11  Updated: 2006/8/29 3:11
 Re: My 1200
cool, is this kit from mcdonald brothers? killer, to change to coilovers you would need to change to a four link system with a panhard rod. a lot more work than the 2 link, which is used to eliminate axle tramp primarily.
clammy
Posted: 2006/8/29 3:58  Updated: 2006/8/29 3:58
 Re: My 1200
how much do you usually pay to have this sort of thing done? and is it worth doing if you plan on putting out a bit of power?
Tyrie
Posted: 2006/8/29 4:01  Updated: 2006/8/29 4:01
 Re: My 1200
My mate has cut the rear end out of a sunny and is going to put it in his 120Y, he reckoned it would be fairly straight foreward
Daveman
Posted: 2006/8/29 7:12  Updated: 2006/8/29 7:12
 Re: My 1200
Could somebody please explain the point of this modification??
As far as I can tell the trailing arms don't stop any sideways movement, they must be adjusted to pivot on the same axis as the front of the leaves and I don't see why they would even eliminate axle tramp?
12OOU
Posted: 2006/8/29 7:27  Updated: 2006/8/29 7:27
 Re: My 1200
axle tramp happens when the diff torques/twists up and changes the angle etc. Those bars prevernt the diff from twisting forward which stops the tramp. Hope that i explained it right.
Daveman
Posted: 2006/8/29 8:56  Updated: 2006/8/29 8:56
 Re: My 1200
Yeah I can see it now, thanks.
PIGDOG
Posted: 2006/8/29 9:24  Updated: 2006/8/29 9:24
 Re: My 1200
so now you just need to modify a falcon watts link( thinks thats what its called) and put that in
much cooler than the commodore panhards that move the diff off centre when you lower them
LAGWAGON
Posted: 2006/8/29 10:21  Updated: 2006/8/29 10:21
 Re: My 1200
caltracks is another name for this type of setup. as said above it stops the housing twisting and 'tramping' the tyres. i guess its only for take off kind of situations. its a more refined version of tramp bars which i used to run.
