Main : Misc Clutch master mounted another angle
[<   Previous  4154  4155  4156  4157  4158  4159  4160  Next   >]
Clutch master mounted another anglePopular
SubmitterkululadotgroenMore Photos from kululadotgroen   Last Update2006/7/14 11:28    Tell a friendTell a friend
Hits1544  Comments7    0.00 (0 votes)0.00 (0 votes)
The bracket was made up from 25x25x2 angle iron. It is bolted straight onto the pedalbox. I did some sizing up inside the car, but took the whole lot out for proper modification, to little space to work inside the car, and fire hasard with the welding...
blob
Posted: 2010/3/9 1:57  Updated: 2010/3/9 1:57
 Re: Clutch master mounted another angle
I'm chasing a remote fill bottle...
Anyone know what this one is out of?
Or one similar?
Cheers,
Sam.
dattoman_1000
Posted: 2006/7/14 12:06  Updated: 2006/7/14 12:06
Besides the remote fill bottle is there any reason you went with a Toyota cylinder ?
kululadotgroen
Posted: 2006/7/14 12:18  Updated: 2006/7/14 12:18
It's a Nissan Sentra master, and I'm still looking for a Sentra slave, to compare it to the Toyota slave. Obviously the Sentra one will be better, but if it's to difficult to mount to the bellhousing casting, which has mounting points and holes for the Toyota one already, I'll go for the Toyota one. There shouldn't be to much difference between the Nissan slave an Toyota slave.
4NIK8
Posted: 2006/7/14 15:07  Updated: 2006/7/14 15:07
Now thats different! Mind me asking why though?
short-coupe
Posted: 2006/7/14 15:23  Updated: 2006/7/14 15:23
i don;t mind the setup, it's different and easy to a degree
LAGWAGON
Posted: 2006/7/14 15:41  Updated: 2006/7/14 15:41
good stuff mate. a mate of mine just did this on his ca to 1200 conversion. no worries about hitting the manifold and you can run the biggest brake booster you like.
kululadotgroen
Posted: 2006/7/22 9:26  Updated: 2006/7/22 9:26
I mounted it inside, because the brakebooster obscures any connection to the clutch pedal below the swivel point. I also think it's going to have beter pedal feel this way, since you have alonger lever doing the work. Besides that, everyone's going to wonder how the hell your clutch works...
