Main : Members : PIGDOG new stance
[<   Previous  140  141  142  143  144  145  146  Next   >]
new stance
new stancePopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2006/7/23 10:07    Tell a friendTell a friend
Hits2445  Comments14    0.00 (0 votes)0.00 (0 votes)
with new front end and shite all springs
JDUB
Posted: 2006/7/25 18:49  Updated: 2006/7/25 18:49
Not too shy to talk
 Re: new stance
Car looks great, are you going to have to flare front fenders?
PIGDOG
Posted: 2006/7/26 1:37  Updated: 2006/7/26 1:37
 Re: new stance
the side you can see needs to be flared a bit, the other side seems to already stick out a bit more
might be a result of lipping the guard as only the other side has been done, so ill see when i get around to fixing the guard you can see
as it is the wheel hits the guard with me pushing down on the front of the car
TnPshow
Posted: 2006/7/23 13:44  Updated: 2006/7/23 13:44
 Re: new stance
Correction - new "tough" stance.
Looks sweet man!
WhiteSedan
Posted: 2006/7/24 12:48  Updated: 2006/7/24 12:48
 Re: new stance
Have you had the stanza struts shortened pigdog?
PIGDOG
Posted: 2006/7/24 12:59  Updated: 2006/7/24 12:59
 Re: new stance
nah didnt get around to shortening the stanza struts, i just changed to 200b ones
basically the same strut but shorter, i had the facilitys to change the spring perch but not to shorten the strut
and i had both struts
thanks for the good words TnP, i like going out to the shed to look at it these days
WhiteSedan
Posted: 2006/7/24 13:03  Updated: 2006/7/24 13:03
 Re: new stance
Ah that explains it, looks sweet too, have you driven with the L series yet?
Ive already done the HG in my beast, didnt get it shaved when i should of, doh!
PIGDOG
Posted: 2006/7/24 13:19  Updated: 2006/7/24 13:19
 Re: new stance
nah havnt driven it yet, need to make a sump and get the tail shaft shortened then dodgy some wires up so i can test it
i think my temp L20b should hold up till i get enough monet to build the L18
the L20 has put up with alot of abuse in my 200b that was a sole burnout car, only thing that i found wrong with it was half the chain guide in the sump
im almost finished though, so close
WhiteSedan
Posted: 2006/7/24 13:24  Updated: 2006/7/24 13:24
 Re: new stance
Compared to the a-series its got so much more torque, very impressive.
What diff you running, if its stock, look at 1200 or 120y auto tailshafts, mines running one!
PIGDOG
Posted: 2006/7/25 10:10  Updated: 2006/7/25 10:10
 Re: new stance
im useing a h150, so i guess i should go measure up a 120y tail shaft
i guess they are shorter than the manual one
WhiteSedan
Posted: 2006/7/25 10:15  Updated: 2006/7/25 10:15
 Re: new stance
Yep try a 120y with a h150, should work. Did the H150 just bolt into the 1200? Did you use the whole housing or just the centre?
Nah just jap auto ones are the same (gearbox end) as the L series gearboxes. Manual ones wont go in the gearbox at all!
PIGDOG
Posted: 2006/7/25 10:17  Updated: 2006/7/25 10:17
 Re: new stance
i used the whole diff, it bolts straight in if you use the extra leaf and ubolts and stuff from the 120y, has the same flange as a h165
i tryed a bluebird tailshaft, it was about 10mm too long
turbosedan
Posted: 2006/7/25 10:23  Updated: 2006/7/25 10:23
 Re: new stance
looks good
WhiteSedan
Posted: 2006/7/25 10:25  Updated: 2006/7/25 10:25
 Re: new stance
To use the extra leaf did you just open the leaf pack and add it, top or bottom? Can you take a photo? I would like to see! '
Do the shocks mount to the diff or the lower u-bolt plate?
PIGDOG
Posted: 2006/7/25 10:36  Updated: 2006/7/25 10:36
 Re: new stance
pm sent
