offset
Quite a regular
From Queanbeyan NSW
hey everyone, just wondering if anyone knows what the actual wheel offset is for a datsun 1200.
i know the stud pattern is 4 x 114.3 but not sure about the offset
thanks everyone
Posted on: 2009/5/11 10:35
Re: offset
From Adelaide, Australia
Posted on: 2009/5/11 10:44
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: offset
Quite a regular
From Queanbeyan NSW
so if there was a set of wheels with the stud pattern 4x 114.3
and the offset of 20/40 they wont fit or what?
thanks
Posted on: 2009/5/11 11:01
Re: offset
Quite a regular
From Queanbeyan NSW
thanks
Posted on: 2009/5/11 11:03
Re: offset
A wheel can only have one offset figure.
It depends on a lot more than just that... if your going any larger than 14" then your going to run into some sort of issue. What width also.
Posted on: 2009/5/11 11:08
IPRA Build
Re: offset
Quite a regular
From Queanbeyan NSW
the wheels are bsa wheels 15 x 6.5
the stud pattern is 114.3 so i guess u can choose the offset
out of 20 or 40
Posted on: 2009/5/11 11:15
Re: offset
Quite a regular
From Queanbeyan NSW
out of 20 or 40
Posted on: 2009/5/11 11:16
Re: offset
Unless they are +20 and machineable to +40??
Posted on: 2009/5/11 11:21
IPRA Build
Re: offset
Quite a regular
From Queanbeyan NSW
o ok.
so the big question is WILL they fit or not.
i dont no if it makes a difference or not but
there going on to a 1200 sedan
Posted on: 2009/5/11 11:25
Re: offset
Standard drum front end?
Do you have the wheels or a link to something about them?
If they are +20 they might just fit under the guards.
Posted on: 2009/5/11 11:29
IPRA Build
