Browsing this Thread:
1 Anonymous Users
Re: A15 cooling issues |
From A-TOWN
Problem sorted.
Running n15 1.8 radiator, 14" thermo hard wired through a relay, camry hose on top and stock hose on the bottom. Temps are perfect. Cheers for all the help.
Posted on: 2013/2/21 8:24
From Malaysia
Hello all My Dat 120y Excellent. Now using Elctric fan from Evo 3 Mitsubishi replacing the old fan. Temp problem still cannot solve. Temperature is still at 3/4 top of the gauge most of the time. Any Idea to solve. p/s engine upgrade to A15 from A12. Original radiator
Posted on: 2013/2/25 2:29
Registered Users Contentmaster Usermaster
A15 needs a slightly larger radiator than A12. Otherwise it will run hot at speed.
With an A12 radiator, it should run cool at idle. If this is your condition (normal at idle, hot at speed), upgrade to A15 radiator.
Posted on: 2013/2/25 2:37
From Malaysia
thanks , make thing clearer.. i should look for new rad..the cost is killing me (old junk rad still at high cost ~ RM150=USD50).
Posted on: 2013/2/25 2:58
