A12 M30Head onto A15 Block
Interested to know if an A12 M30 head would bolt directly onto an A15 Block?
The A12 head I have is heavily worked, hence the reason for wanting to keep using it.
Thanks
Posted on: 2019/3/27 0:54
Re: A12 M30Head onto A15 Block
A14/A15 engine block can use every A-series head known to man
In some cases you may have to swap inlet & exhaust manifolds also
Early engines (A10 and early A12 to 1973) need certain heads
Posted on: 2019/3/27 5:04
Sweet! Hopefully I can gain some much needed torque.
Posted on: 2019/3/27 17:53
@ddgonzal Would my high lift cam from the A12 fit in the A15? I'm guessing if I use the cam, I'll need new lifters, the longer A15 pushrods?
Cheers
Posted on: 2019/3/27 17:54
Use the pushrods that match the block. A14/A15 use the long pushrods
Late model engines (1974 up) all use the same cam blanks so the different finished cams are interchangable. But 1970-1973 A12 uses a different style cam
Yes, always use new lifters (or re-faced lifters) when changing the cam. I reckon you could re-use the lifters with the cam if you number them when removing from the A12 and installing in the A15 (both use the same lifter part number)
High-lift cam? Be sure to check the piston-to-valve clearance as A12 and A15 pistons have different dish sizes and or dish shape
Posted on: 2019/3/28 4:33
