#1 E15 Carb will it fit?
dan_fjt Posted on: 2004/2/26 9:44
Question, I need a new carb to replace the flogged one on my A14, has anyone used the E15 carb? Seems like it might be a better upgrade.
#2 Re: E15 Carb will it fit?
dattodevil Posted on: 2004/2/26 10:13
If you swap the lower gear over, machine the adjuster face and adapt the original A15 steel adjuster plate to the E15 distributer. then yes it will fit.
#3 Re: E15 Carb will it fit?
phunkdoktaspok Posted on: 2004/2/26 10:28
carbie not dizzy
#4 Re: E15 Carb will it fit?
holeshot Posted on: 2004/2/26 11:12
What is in his cordial, I WANT SOME.I read carby to
#5 Re: E15 Carb will it fit?
dattodevil Posted on: 2004/2/26 11:21
I was wondering what thread I put that in
I couldn't find it again, trying to locate an A15 electronic dizzy on ebay and submitting post at the same time does not work to well together with sleep deprivation
But on the point of carbies any thing will fit if you've got the time but the easiest way is to put an A15 one on with auto choke, works a treat
#6 Re: E15 Carb will it fit?
dan_fjt Posted on: 2004/3/5 10:51
Well its a long story.. I haven't had any luck finding one, and the one I had didn't survive its trip to the garage floor from the attic :( Damn my car is running like crap flatspots from hell , and the carb butterflies have more play than Michael Jackson in a primary school.
