Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
sparkplugs?
Rogue
Posted on: 2004/8/5 1:00
Can anyone tell me the difference between a NGK BP6E plug and a NGK BP6ES.
I`m not quite sure why the 'S' is tacked on the end ? Might be a good question for an Auto sparky!
#2
Re: sparkplugs?
scottyb
Posted on: 2004/8/5 3:24
Rogue:
B - thread diameter (14mm) P - projected insulator type 6 - heat range (2 is hot, 11 is cold) E - thread reach (19mm) S - standard 2.5mm centre electrode. If this symbol is not on the plug type, then it has a factory centre electrode. not sure of the size. The S means the electrode is a little more fandangle.
#3
Re: sparkplugs?
Cable_Tie
Posted on: 2004/8/5 4:07
The S stands for Copper core centre electrode (SUPER) . . . I guess it was an advanve in it's day!
#4
Re: sparkplugs?
1200GXman
Posted on: 2004/8/5 7:41
While we are on the subject of spark plugs.
How tight must they be turned in when installing them. Anybody have the Nm torque setting? Must I put a light film of oil on the groves before installing them? Thanks
#5
Re: sparkplugs?
Dodgeman
Posted on: 2004/8/5 10:59
For those that like a lot of boost, particularly if you add a little NOx, try NGK BPRxEIX plugs
The [x] is the heat range of your choice. I will be using BPR6EIX plugs in mine & i bought a set last week. These are one of the few plugs that will live with NOx. They are not cheap, but will probably outlive your engine if you are into thrashing. 1200GXman My B310 [SUNNY] Factory service manual [engine maintainance section] says plugs should be tightened to 15 - 20 N.m 1.5 - 2.0 kg.m 11 - 14 ft.lb [pick one] It makes no reference to lubrication of the threads, so put them in CLEAN & dry. Chris P.S. The "R" is for resistor, & no, it won't hurt performance, but for me, it will help ensure that my original AM radio can receive "Radio National" nice & clear. You can view topic.
