Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
diff rebuild
ade
Posted on: 2004/8/10 23:03
I have just had my ute diff rebuilt.
All up the cost was $580 this included welding in the Genuine Nissan baffles (part number 43015-25720) new bearings/seals wheel bearings. I think I got touched as I have to do the final assembly and have to source the gaskets. Have any of you fellows used a good sealant inplace of gaskets when assembling a diff ?? Any tips would be appreciated. Cheers Ade
#2
Re: diff rebuild
B110SSS
Posted on: 2004/8/11 1:26
Hi Ade,
If you are talking about installing the diff head into the housing use RTV ( silicon ) instead of a gasket - it works fine.Just make sure that both surfaces have been thoroughly cleaned and that there is no residue oil lying in the housing that could spew out when the head goes in. Cheers Dave
#3
Re: diff rebuild
1200rallycar
Posted on: 2004/8/11 3:14
silicon is your friend, hehe, i hardly ever buy gaskets anymore
#4
Re: diff rebuild
dattodevil
Posted on: 2004/8/11 9:19
3 Bond, the best sealant you can use, it costs about $20 dollars for a small tube, but you pay for quality. It is the same sealant the Japs use on their engines.
#5
Re: diff rebuild
ade
Posted on: 2004/8/11 9:43
Thanks guys,three replys and all point towards a silicone based sealand as Homer would say MMM Silicone.
Thanks Ade
#6
Re: diff rebuild
dattodevil
Posted on: 2004/8/11 10:03
3 Bond is not silicone based. Silicon is an acid cure where as 3 bond is a sagless anerobic type. It cures by contact with moisture in the air, about 3 hours, but sets harder and better than silicone.
