Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Running unleaded fuel in a leaded car and alternate fuels in an A-series
steveo
Posted on: 2005/1/29 14:25
Whilst on holidays in my home town of newcastle(NSW) over christmas, i noticed that service stations are phasing out leaded petrol instead, every time you fill up you can buy an additive to add with the unleaded fuel,
I thought i would start a thread to expand on this idea, What would happen if you ran unleaded in a car without using the additive? What difference would premium unleaded make? And, is it possible to make a leaded motor into an unleaded motor? does the head have to be modified and the carby? Any thoughts on this?
#2
Re: Running unleaded fue in a leaded car
godabaute
Posted on: 2005/1/29 14:36
on my first ute i had an a14 i ran that on premium unleaded and as far as i am aware it had no mods to the engine. my second ute had an A15 i used the additive once and it never ever ran the same again. third ute with the A15 im planning to run premium again but this time i will put hardened valve seats n stuff in. im not really sure what i would have to do but i recon i could do it if somebody told me.
#3
teretonga
Posted on: 2005/1/29 18:46
I have never run additive or leaded in any of the A series motors I have owned. Never had a problem with recession etc. and I did over 160 000 k's on my most recent A14 and it was already a high km engine when I got it. Only problem I ever had was letting Converted drive it at an Autokhana.
#4
converted
Posted on: 2005/1/29 20:41
which was driven to class honours I might add....
plus it blew the cobwebs out of it...
#5
teretonga
Posted on: 2005/1/29 20:55
and the fan belt too... And blew out coolant and did you stop??? Car had to go to the Crusher after that. Broke my heart and I had to leave the country. Feral flamin' Aussies.
#6
converted
Posted on: 2005/1/29 21:07
was engine ok??? It still took class honours...
talk about feral ...how bout the 10 year olds who tried to execute you with a BB gun???
#7
Freak
Posted on: 2005/1/29 23:57
A series engines are ok because they have an alloy head which means they already have to have hardend valeseats so unleadeded wont hurt them. If you run unleaded on a cast iron head which hasn't had hardened valveseats inserted the old soft ones will wear out very quickly.
THe only difference premium will make is that it is 95-98 octane which is close to leadeds 96 which means you wont have to retard timing to stop pinging.
#8
godabaute
Posted on: 2005/1/30 5:39
I didnt know that freak. good info. isnt there a problem with unleaded fuel burning hotter or something?
#9
Freak
Posted on: 2005/1/30 6:59
Not that I am aware of. The only difference is the obvious. One used to have lead/now lead replacement and one has no lead. The lead in the fuel acts as a lubricant. Without hardend valeseats and no lubricant they wear very quickly. To have a leaded car converted to run uleaded only requires changing of the valveseats to harder ones which will be able to take unlubricated punishment.
#10
steveo
Posted on: 2005/1/30 10:09
So, is there any difference in performance? better or worse?
