#1 a15 v's e15
datobuggy Posted on: 2005/2/13 11:35
does the e15 bolt up to the a15 gearbox? or any other rear drive box? has this been done before in a ute or coupe????ken
#2 Re: a15 v's e15
TnPshow Posted on: 2005/2/13 11:42
I've heard it bolts up with the exception for one bolt - use the search button on the left for more info.
TC
#3 Re: a15 v's e15
datobuggy Posted on: 2005/2/13 11:56
if they do bolt up whats the go with clutch and flywheel??has it been done before???
#4 Re: a15 v's e15
who_your_datty_1200 Posted on: 2005/2/13 12:25
Think about where the dizzy sits on the E series.............
#5 Re: a15 v's e15
sunny Posted on: 2005/2/13 14:04
the dizzy is easy fixed
just like most things you will probably be the first
so get your trusty ruler out and start measuring ,do you have an e15 ? if not get a cheap (stuffed one ).
