indicator ( think fuse repeater) problem HELP NEEDED
From penrith
hello eveyrone i recently bought a sr20 1200 ute
today in traffic noticed the right indicator wasnt working but seem to click twice as often as the left when i listened but still no lights.
so i check the clicker and it looks fine( no power on the right indicator tho)
so i check that metal cylinder thing down more above the foot pedals. dad told em to swap the wires over and i did it worked fine then then i tried puttin it bak to normal(as in wires not swapped around) then same problem right aint working. swapped em number of times then it worked again ( normal wires) but like tried to keep the light on for longer between repeats and is like dodgey ay like flickering n stuff
it says on it :
NILES
TF642-12.8v
23Wx2+6W+3.4W
90C/M
DON'T DROP
JAPAN
so wanna get a new one quick smart. Is it a repco item or should i go to nissan or wreckers or look in trader?
Posted on: 2005/4/7 11:31
Subject Poster Date
     indicator ( think fuse repeater) problem HELP NEEDED Mr_Turbo 2005/4/7 11:31
       Re: indicator ( think fuse repeater) problem HELP NEEDED tom210 2005/4/8 1:29
         Re: indicator ( think fuse repeater) problem HELP NEEDED b310gx 2005/4/8 11:44
           Re: indicator ( think fuse repeater) problem HELP NEEDED Mr_Turbo 2005/4/8 14:32
             Re: indicator ( think fuse repeater) problem HELP NEEDED tom210 2005/4/10 1:31
               Re: indicator ( think fuse repeater) problem HELP NEEDED Mr_Turbo 2005/4/10 3:39
