#1 bonnet scoops- who's gottem and what did you use?
funkeyman Posted on: 2005/6/27 12:58
Just toying with the idea of fitting a bonnet scoop to allow some fresh air over the sidedraft.
As you all would know, A series sidies fit snug over extractors and would obviously draw warmer air as well as warm air under the bonnet.
I was thinking of some thing like a scaled down version of the XW GT bonnet scoop.
Any ideas?
J.
#2 Re: bonnet scoops- who's gottem and what did you use?
_steve_ Posted on: 2005/6/27 13:09
i am going 2 use a hornet scoop
#3 Re: bonnet scoops- who's gottem and what did you use?
Rogue Posted on: 2005/6/27 14:20
I`ve got exactly what your talking about bolted on my ute.
Rarespares in Sydney and cost approx 45 bucks.
You can have a look at my photos on this site.
#4 Re: bonnet scoops- who's gottem and what did you use?
boofhead Posted on: 2005/6/27 16:09
Nissan GU Patrol bonnet scoops don't look too bad if you're after something with a bit of size ?? around $120 from Nissan if i remember correctly.
#5 Re: bonnet scoops- who's gottem and what did you use?
vex66 Posted on: 2005/6/27 16:24
If you don't want the look of a bonnet scoop or just want something different, you can buy a stainless steel louvre vents. Go to www.bla.com.au & look under engine room vents. There are a few different types & they look to be very well made.
#6 Re: bonnet scoops- who's gottem and what did you use?
sidedraught Posted on: 2005/6/28 0:01
I put an aluminium sheet between the webers and the extractors to keep the heat away and cut a hole behind the grille with a big funnel in it to direct fresh air onto the carbs.
Works very well and doesnt wreck your hood.
#7 Re: bonnet scoops- who's gottem and what did you use?
pro-240c Posted on: 2005/6/28 3:18
you can get monaro mudguard flutes from rare spares in metal for $45 a side.
a recessed bonnet perforation would be very cool indeed.
sidedraught's idea is also a good one. -great for sleeper value.
#8 Re: bonnet scoops- who's gottem and what did you use?
dattoman_1000 Posted on: 2005/6/28 12:23
This is mine
Its moulded into the bonnet as one piece fibreglass. It doesn't have an opening at the front as the engine sits beside me and I really don't need any airflow onto the front suspesnsion.
I'm going to make a few with the hole cut out at the front for street vehicles when I can get my lazy arse into the shed.
#9 Re: bonnet scoops- who's gottem and what did you use?
sidedraught Posted on: 2005/6/28 13:51
Neil these would have to be two of the best racing photos I have ever seen posted on this site.
#10 Re: bonnet scoops- who's gottem and what did you use?
dattoman_1000 Posted on: 2005/6/28 14:49
Thanks
Can't take the credit though myself
Phil takes good pics....... hope he doesn't mind me borrowing them
