GT28rs turbo on CA18det
From Brisbane
My 1200 is getting a rebuild, and the turbo is stuffed - will cost as much to rebuild as to purchase a new turbo!
Does anyone know exactly what is involved to fit a gt28rs to a ca18det? All i have read is a bit vague -
1 the manifold flange is the same but doesn't quite line up so one bolt must be slotted.
2. oil lines must be modified (heated and bent into shape)
3. grind a bit out of the exhaust manifold (to accommodate larger compressor housing) OR use a spacer and longer studs.
I was going to use GT25 but was a bit complicated.
thanks,
justin
ps my low compression (120psi) was due to a cracked piston ring and stuffed valves. I have forged items now.
Posted on: 2005/7/22 7:32
Subject Poster Date
     GT28rs turbo on CA18det ogyris 2005/7/22 7:32
       Re: GT28rs turbo on CA18det Demojob 2005/7/22 10:55
         Re: GT28rs turbo on CA18det dattodude 2005/7/22 11:13
           Re: GT28rs turbo on CA18det DATT-MATT 2005/7/23 9:33
       Re: GT28rs turbo on CA18det ogyris 2005/7/23 10:17
         Re: GT28rs turbo on CA18det dattodude 2005/7/23 11:42
           Re: GT28rs turbo on CA18det Demojob 2005/7/23 12:43
