#1 suspension?
datobuggy Posted on: 2005/11/21 11:32
hi guys, i need some info on suspension,for my buggy i would like to use something with upper and lower wishbones not struts, my buggy weighs 450kg,so not much weight in front. does the datsun 1000 have this ?or can you recommend something else.....thanks ken
#2 Re: suspension?
datobuggy Posted on: 2005/11/21 12:22
can any show me a photo of datto 1000 front end???? i searched the tech section plenty on 1200 nothing on 1000 any help would by great ...thanks ken
#3 Re: suspension?
BigV Posted on: 2005/11/21 21:22
have a look at a gemini
#4 Re: suspension?
COUP1200 Posted on: 2005/11/21 23:03
Heres a pic of the F/End from my buggy. Open in new window
#5 Re: suspension?
datobuggy Posted on: 2005/11/22 2:07
thanks for your reply,does your camber change when the front goes up and down? and have you gotfront brakes? thanks ken
#6 Re: suspension?
datobuggy Posted on: 2005/11/22 12:52
hi, can anyone please show a picture of a 1000 front end,,, thanks ken
#7 Re: suspension?
datobuggy Posted on: 2005/11/23 10:39
hi, if no one has a picture of a datto 1000 front end can someone recommend another site where i might find one??? any help would be great thanks ken.
#8 Re: suspension?
Dodgeman Posted on: 2005/11/23 11:55
#9 Re: suspension?
datobuggy Posted on: 2005/11/24 1:13
thank you very much dodgeman, looks like upper and lower controlarms with transverse leaf spring ,this will do the job i can add or remove leaves to soften or stiffen very good ..does anyone have one these for sale?? thanks again dodgeman ...ken
#10 Re: suspension?
phunkdoktaspok Posted on: 2005/11/24 7:14
The towers to which the top arms are mounted is part of the car (its welded on). You would have to cut them off and mount them on your buggy's rails or make new mounts to attach to the crossmemeber. The gemini suspension mentioned earlier is all one piece ready to bolt on.
