#1 stanza struts in - what outer tie rod end for replacement?
1200rallycar Posted on: 2006/4/4 12:35
i must be getting old... i cant remember what i used and never knew the proper names for these bits but...
i think i used stanza outer tie rod ends with the 1200 adjusting rod
does this sound right?
was gonna order some tie rods ends tomorrow and wanted to check i was getting the right ones...
as an update... ive been slack with the new 1200... but its coming along... engines in, some small amount of wirring, replace rear wheel bearings, some fuel line plumbing (pumps are mounted) and battery mounting to be done before she's on the road, cant wait to get some pics once its complete...
#2 Re: stanza struts in - what outer tie rod end for replacement?
Grunterhunter Posted on: 2006/4/4 12:41
I'm pretty sure the tie rod ends are the same part for stanza, 1200 and 120y. I used the standard 1200 adjusting rod with no probs
