#1 Rear axle question..
Duncan Posted on: 2006/10/10 4:55
Are the 1200 rear axles interchangeble from the Coupe to the Sedan? I've never looked under a sedan, but somehow I seem to recall someone mentioning the shock mounts are different..
Thanks!
#2 Re: Rear axle question..
dattodude Posted on: 2006/10/10 5:05
Same diff maker, same Wheel Base, same drums = same axle.
Ute's with the H165 are more likely to be an exception.
Chris
#3 Re: Rear axle question..
carjunkie Posted on: 2006/10/10 6:14
shock mounts are different, but if you use the bottom plate that mounts to the leaves from the coupe a sedan diff will go straight in as the coupe shock mounts are located on these.
Have done it myself to save pullin a blown diff apart.
All other parts interchange( axels, centre, drums, ect) except wheel cylinders which are different bore due to front disks on coupe.
Hope this helps
