#1 nolethane rear bushings.
A14force Posted on: 2006/10/24 9:25
Here's the deal,
At the start of the year when I was all cashed up after a fire, I bought what I thought to be a full set of noltec bushes for the back end of my 1200 sedan. (I do some work for the rural fire authority, and they pay well)
However I was looking at the parts today,(Yeah I'm a slack ass and haven't fitted them yet) and it appears that I didn't get the bushes for between the front spring hangers and the "chassis".
I took a look at the noltec website, and they don't list a part for it. What has everyone else used.
#2 Re: nolethane rear bushings.
converted Posted on: 2006/10/24 9:31
dont get the 4 ones for the front "hanger" keep them stock as it needs a little bit of plyability. This is one of the secrets of a race setup for a 1200. Use nolathane for all other bushes in the rear suspension
#3 Re: nolethane rear bushings.
WhiteSedan Posted on: 2006/10/24 9:45
Converted, in the competition manual on here, im sure it says to use the stock rear leaf eye busing, delrin/nolathane front eye bushing and alloy busings in the chassis rails. Thats what im am currently doing with my sedan.
#4 Re: nolethane rear bushings.
DATTOWHORE Posted on: 2006/10/24 9:56
I measured up the bushings and found some in the back of the nolathane cataloge to fit the chassis mounts in my coupe. I wouldn't have thought that you would need movement there, but i don't have the experience that converted has about these things.
#5 Re: nolethane rear bushings.
WhiteSedan Posted on: 2006/10/24 9:57
DATTOWHORE, thats why they use alloy there. As the leafs locate the diff in the car, you dont want it moving from side to side at all. I would only recommend this for a serious track car, definitely not for the road, wear will be too high.
#6 Re: nolethane rear bushings.
converted Posted on: 2006/10/24 11:02
I havent worked out the physics why this is the case however it works and works very very well.
#7 Re: nolethane rear bushings.
A14force Posted on: 2006/10/25 7:49
Anyone got a part number?
#8 Re: nolethane rear bushings.
DATTOWHORE Posted on: 2006/10/25 9:28
For the nolathane?
#9 Re: nolethane rear bushings.
short-coupe Posted on: 2006/10/25 10:34
i used the back rear hanger (x2 sets), and drilled out the centre to 13mm to suit the front rear hanger, outside dimensions are the same,
