#1 120y rear sway bars
dats-me Posted on: 2006/12/12 15:22
has anyone put a rear sway bar in their 120y? not for track use just for stiffness and fun. there are 16mm and 18mm ones on whiteline, is there any other places that sell them too?
whiteline
#2 Re: 120y rear sway bars
dats-me Posted on: 2006/12/13 10:51
anyone?
#3 Re: 120y rear sway bars
WhiteSedan Posted on: 2006/12/13 11:01
Not really worth running, not even necessary for the track, some good oil shocks and a tad stiffer leafpack will be enough.
#4 Re: 120y rear sway bars
Datsun_210 Posted on: 2006/12/13 13:18
Addco makes a 1" sway bar for the front and 5/8" for the rear. Hope that helps you.
#5 Re: 120y rear sway bars
B210sleeper Posted on: 2006/12/13 17:16
The rear swaybar is only for the leaf spring 120Y's i believe.
they compensate for body roll, so do you have excessive body roll?
#6 Re: 120y rear sway bars
dats-me Posted on: 2006/12/14 2:28
thats what im after. i have the leafs in the back. i feel like it will roll over before it will slide out. also the front wheel comes off the road when cornering (hard) how can i fix that?
#7 Re: 120y rear sway bars
B210sleeper Posted on: 2006/12/14 4:09
lowering the car helps too, lowering the car and inch or 2 can do wonders.
stiffening the rear end could help.
Leaf spring rear end experts ??
#8 Re: 120y rear sway bars
tom210 Posted on: 2006/12/15 5:19
same.. ive had that wheel up a few times, motorkhanas are one place lol
#9 Re: 120y rear sway bars
B210sleeper Posted on: 2006/12/15 8:24
hehe that's what i'm thinking, I've never lifted the front wheel. maybe needs some bushings if it's that easy.
#10 Re: 120y rear sway bars
dats-me Posted on: 2006/12/15 10:25
yeh ive got 2" blocks to go in and some lovell springs too. ill see how it goes with them in it
