#1 accellerator cable question
shaun Posted on: 2007/1/23 10:03
can i use a standard 1200 speedo cable with my twin 45s
and if so does anyone have one they want to sell???
#2 Re: accellerator cable question
Mildman Posted on: 2007/1/23 10:05
by shaun on 2007/1/23 20:03:29
Speedo cable yes as it goes no where near the carbies....but I'm guessing you meant accelerator cable, again I believe yes you just need to set up some linkages to move both carbies at once.
#3 Re: accellerator cable question
shaun Posted on: 2007/1/23 10:07
#### yeah sorry mate i even wrote accelerator in the post title
yes i have the linkages as a center pully so they both work at once
#4 Re: accellerator cable question
Curtis Posted on: 2007/1/23 10:29
if u cant get that to work i suggest get a push bike brake cable kit.worked a brezze for me.
#5 Re: accellerator cable question
1200rallycar Posted on: 2007/1/23 10:37
linkages are a custom thing pretty much, if they came with an a-series manifold it should work with the a-series cable, if not you may need to do some adaption
#6 Re: accellerator cable question
shaun Posted on: 2007/1/23 10:42
i tried to use a universial cable but it didnt work it just kept on pulling through the outer casing as well as i couldnt secure the cable to the fire wall or the linkages
