A15 test run bodge loom....
From The garage, NZ
Have an a15 thats just had a gasket set. All put together. Mounted it to a crossmember and attached the clutch and gearbox tonight. Its on the floor. Wanting to test run it on the foor to see that it runs before i get it into anything and find it needs... (insert annoying part).
Just wanting some ideas as far as a quick loom i can chuck together to to get it going.
I have the complete loom from my wagon, can i attach everything i have to the loom and itll run, grounding it all to the engine obviously.
Still has everything attached and labeled on the loom so wouldnt be hard.
ideas....
Posted on: 2008/7/22 10:17
Subject Poster Date
     A15 test run bodge loom.... cheater_5 2008/7/22 10:17
       Re: A15 test run bodge loom.... revhead001 2008/7/22 10:25
         Re: A15 test run bodge loom.... cheater_5 2008/7/22 10:31
           Re: A15 test run bodge loom.... revhead001 2008/7/22 10:51
             Re: A15 test run bodge loom.... cheater_5 2008/7/22 10:54
               Re: A15 test run bodge loom.... revhead001 2008/7/22 11:25
                 Re: A15 test run bodge loom.... PIGDOG 2008/7/22 13:26
                   Re: A15 test run bodge loom.... ddgonzal 2008/7/22 17:06
                     Re: A15 test run bodge loom.... cheater_5 2008/7/22 21:48
                       Re: A15 test run bodge loom.... revhead001 2008/7/22 22:00
