#1 ca18det Perth
bailz Posted on: 2009/2/12 5:30
who in perth has done the ca18det into ute or coupe etc. just wondering how many are around cause i am going to be starting my conversion shortly i wanna see the little things that might make it an easier install if i can prefab a few things...
cheers
#2 Re: ca18det Perth
old_school Posted on: 2009/2/12 5:37
Have a CA18DET in a 1200 coupe, which you are welcome to come and look at. Registered last week and fully engineered.
If I done it again would use Maddat crossmember. I made my own but ran into issues as a result. My engine sits further forward than Mad Crossmember engine placement. Meant had issues with clutch slave/steering arm clearance. Limited room for radiator and because my engine sits lower I needed to make custom sump
#3 Re: ca18det Perth
perthute Posted on: 2009/2/12 5:42
mine was ca18det so i can show you crossmember gearbox member brake booster ect ect
#4 Re: ca18det Perth
bailz Posted on: 2009/2/12 6:57
i will take you guys up on the offer. i am looking forward to doing this conversion
#5 Re: ca18det Perth
perthute Posted on: 2009/2/12 7:07
when u starting the convershion ?
#6 Re: ca18det Perth
datokid Posted on: 2009/2/12 8:22
how much power difference is there between a CA18DET and a SR20DET and which is easyer to fit in my ute
#7 Re: ca18det Perth
old_school Posted on: 2009/2/12 8:37
Datokid, did you not ask this before?
The CA is by far the easiest and unless you want to challenge the WA Transport Dept a SR20DET Can not be registered in WA.
A CA Turbo will be much more powerfull than a non turbo sr20.
There are heaps of specs on the net for the various sr20 engines and the ca engines. Plus alot of info in the wiki.
#8 Re: ca18det Perth
dazza1200 Posted on: 2009/2/12 8:38
i need to do a crossmember too
if we can borrow jordys maybe we can do 2 at the same time
#9 Re: ca18det Perth
jeffroj Posted on: 2009/2/12 9:15
you are welcome to come and have a look at ca18detmans coupe and have a look at his crossmember (sounds bad)
#10 Re: ca18det Perth
bailz Posted on: 2009/2/12 23:51
i will be starting the convo asap. i am just gunno so some wiring on the engine and get it so i can just bolt the sucker in and fire it up.... in theory lol.
when can i come have a looksie? maybe get dazza to come have a look at the same time to get a few specs...
