Question on engine mounts A15 engine swap
From Perth WA Australia
I have started the engine swap and after reading the tech section I would appreciate some clarification.
1.I am swapping from late model A12(120 Y) to an A15 in a 1200 coupe.
2. The engine mounts not the crossmember have alrady been modified to suit the later model A12 engine.
3. Do I have to raise the mounts so the engine sits lower to suit the A15. The wiki article says the A15 is about 25 mm higher than the A12,or will the same mounts do? if so is 25 mm enough.
4. I am running a blow through turbo set up so dont have any room to play with if the engine is higher.
Any advice appreciated
Posted on: 2009/4/29 14:36
Edited by ThomasSymes on 2009/4/30 3:42:20
Edited by ThomasSymes on 2009/4/30 4:59:13
Subject Poster Date
     Question on engine mounts A15 engine swap ThomasSymes 2009/4/29 14:36
       Re: Question on engine mounts A15 engine swap Dundee1000 2009/4/29 14:59
       Re: Question on engine mounts A15 engine swap Mawler1 2009/4/29 16:03
         Re: Question on engine mounts A15 engine swap Mildman 2009/4/30 1:38
       Re: Question on engine mounts A15 engine swap retrorally 2009/4/30 3:48
         Re: Question on engine mounts A15 engine swap Mildman 2009/4/30 4:04
           Re: Question on engine mounts A15 engine swap Anonymous 2009/4/30 4:12
       Re: Question on engine mounts A15 engine swap retrorally 2009/4/30 5:39
         Re: Question on engine mounts A15 engine swap Anonymous 2009/4/30 5:41
           Re: Question on engine mounts A15 engine swap ddgonzal 2009/4/30 6:46
             Re: Question on engine mounts A15 engine swap Mildman 2009/4/30 7:12
       Re: Question on engine mounts A15 engine swap ThomasSymes 2009/4/30 12:48
         Re: Question on engine mounts A15 engine swap WhiteSedan 2009/4/30 13:10
       Re: Question on engine mounts A15 engine swap ThomasSymes 2009/4/30 13:22
