#1 instrument cluster and bezel removal
mazdat Posted on: 2009/7/9 23:28
i have a 73 datsun 1200 which i'm trying to remove the instrument cluster and bezel, how the can i do that?, i don't see any screws or anything, if anyone has any info to do so, let me know, thanx in advance!!
#2 Re: instrument cluster and bezel removal
ddgonzal Posted on: 2009/7/10 2:40
The instrument cluster has two screws up behind the dash. You'll also need to disconnect the round connector, sppedo cable, kmnobs and various other thing. And lower the steering column or at least remove the column cover
It is actually (slightly) easier to remove the whole dash assembly.
Pictures and steps: Dash RemovalQuote:
Instructions
The only tool needed to remove and replace the cluster is:
No. 1 (small) philips head screwdriver
#3 Re: instrument cluster and bezel removal
mazdat Posted on: 2009/7/10 5:36
where exactly are 2 two little screws? i'm not sure if i'm able to remove the whole entire dash, i might mess something up, thanx ddgonzal!!!!
#4 Re: instrument cluster and bezel removal
ddgonzal Posted on: 2009/7/10 6:01
Check the photos at the link in my last message. It is in the section "Cluster Removal"
#5 Re: instrument cluster and bezel removal
mazdat Posted on: 2009/7/10 15:29
i see them, i'm going to try it, thanx again
