What sort of ignition timing are you guys running???
From Perth
Hey guys,
I am just trying to get an Idea of what sort of timing I should be running on an A-series. Also what I should be running for startup timing. 10 degrees sounds right? I have a mild cam (mystery) mild portwork, a14 block, a15 head.
I am not after precise timing values, those can only be tuned while on a dyno or driving. Just some settings that people are running to get some starting figures to work from.
Cheers -Liam
Posted on: 2009/8/2 10:45
Subject Poster Date
     What sort of ignition timing are you guys running??? Retal052 2009/8/2 10:45
       Re: What sort of ignition timing are you guys running??? woody 2009/8/2 11:05
         Re: What sort of ignition timing are you guys running??? Retal052 2009/8/2 11:19
           Re: What sort of ignition timing are you guys running??? woody 2009/8/2 11:24
             Re: What sort of ignition timing are you guys running??? Retal052 2009/8/2 11:28
               Re: What sort of ignition timing are you guys running??? ddgonzal 2009/8/3 2:08
