Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
R31 fuel tank
jeffery
Posted on: 2009/10/14 13:00
Hey guys I have tried to search in the wiki but everytime I hit search it crashes on me... Anyways, I have installed a r31 fuel tank into my ute and am plumbing it in. If your looking at the top of the tank with the 2 lines facing at you from the pump which is the supply and which is the return?
Cheers Dan
#2
Re: R31 fuel tank
nick_m
Posted on: 2009/10/14 21:43
just unbolt the pump and pull it half out. It will be prety obvious which is which, the return is the pipe that doesn't have a fuel pump on the end :)
#3
Re: R31 fuel tank
LittleFireyOne
Posted on: 2009/10/15 1:42
so they're both the same size pipes I'm guessing
#4
Re: R31 fuel tank
jeffery
Posted on: 2009/10/15 2:06
Yeah they are both the same size pipe... And I was hopeing to not have to pull the tank out again but I may have to I guess
#5
Re: R31 fuel tank
nick_m
Posted on: 2009/10/15 3:04
Put power to it and connect some hose to them and run into a bucket and see which one spits fuel out.
#6
Re: R31 fuel tank
jeffery
Posted on: 2009/10/15 3:12
Ok I have been told that the pressure side is the one closest the outside of the tank... I'll try it out and see how it goes I suppose... Thanks guys!
#7
Re: R31 fuel tank
sunny_boy
Posted on: 2009/11/21 12:51
im sure you have heard of a guy named Kev Rowlie i dont have his number on me but i can get it if you want? he knows everything about this stuff. (r31 tank & ca18)
