Door to fender alignment ???
From Seattle ,WA.
I put the doors back on the coupe after the filler/epoxy were sprayed & new factory hinges were installed. Then I hung the fenders & started to try & line things up, not as easy as I thought it'd be & frustrating to say the least
I've got issues with the bottom of one door protruding out too far & the other door the being in too far at the top & that fender gap not right. Both doors line up with the rockers pretty well & if I remember right these are the same doors I took off the car.
I'm just wondering if any of you have some adjustment tricks I could try, I've been fiddling with the hinges & also wondering if I should bore the hinge holes a bit more out to create some more adjustment.
Any thoughts / idea's & experiences appreciated!
Thanks, Evan
Posted on: 2009/11/11 5:53
Subject Poster Date
     Door to fender alignment ??? edp 2009/11/11 5:53
       Re: Door to fender alignment ??? aidaniel 2009/11/11 5:56
         Re: Door to fender alignment ??? ddgonzal 2009/11/11 6:09
       Re: Door to fender alignment ??? edp 2009/11/11 16:14
         Re: Door to fender alignment ??? Rallytwit 2009/11/11 21:25
           Re: Door to fender alignment ??? crzy_1200_ute 2009/11/12 3:03
